Topic: Issues in a costom board Arduino Core (Read 590 times) previous topic - next topic
APansza
Hello,
I have some troubles with the Arduino core board that I build.
 I use an ATMEGA328PB-MU and a CP2110-F01-GM for the USB connection.
I used an AVRISP mkII from Atmel (with an external power supply)and the Arduino IDE to burn the bootloader. I don´t have any problem n that part.
When I finish burning the bootloader, immediately the LED  that I connect, started to blink (Like the blink LED example), connecting with an external power supply.
When I connected directly I can see the normal behavior (The blink led behavior), but when I connected directly to the computer by USB port the blink LED is faster like if the MC enters like a programming mode.
I can´t program with the Arduino IDE.
The ATMEGA328PB-MU is directly connected to the 5V, I don´t use a LDO.
Do you have ides what is the problem and how to solved it?
Regards.
