Topic: Arduino Mega and V.KEL GPS Module (Read 43 times) previous topic - next topic
Jnaj
Hi guys,
This is my first time posting on here, but i have used these forums for years to help. I am in the middle of a project using a V.KEL GPS and Arduino mega. I want to use this chip to show current speed as well as current time. Also, I am trying to get it to show my course and lat and long. But i would much rather have it read speed and time first. I have code that i gathered together over the years trying to make this work but have never gotten it to work. I am just trying to have it simply write into the serial monitor.
GPS Module: https://abra-electronics.com/wireless/gps/modules/vk2828u7g5lf-ttl-ublox-gps-module-with-antenna.html
code below:
#include <TinyGPS.h>
#include <SoftwareSerial.h>
TinyGPS gps;
const int rxPin=3;
const int txPin=4;
int led=13;
SoftwareSerial mySerial(rxPin, txPin);
long lat, lon;
unsigned long fix_age, time, date, speed, course;
unsigned long chars;
unsigned short sentences, failed_checksum;
//int year;
//byte month, day, hour, minute, second, hundredths;
  Serial.begin(9600);            //Set the GPS baud rate.
  pinMode(led, OUTPUT);
  pinMode(rxPin, INPUT);
  pinMode(txPin, OUTPUT);
  mySerial.begin(9600);
  digitalWrite(2,HIGH);
  Serial.println("Setup completed");
  delay(2000);
  while (Serial.available())
    digitalWrite(led, HIGH);
    int c = Serial.read();                   // Read the GPS data
    if (gps.encode(c))                        // Check the GPS data
      // process new gps info here
  digitalWrite(led, LOW);
  gps.get_position(&lat, &lon, &fix_age);     // retrieves +/- lat/long in 100000ths of a degree
  gps.get_datetime(&date, &time, &fix_age);   // time in hhmmsscc, date in ddmmyy
  //gps.crack_datetime(&year, &month, &day,    //Date/time cracking
  //&hour, &minute, &second, &hundredths, &fix_age);
LAT();
Serial.println("");
LON();
Serial.println("");
TIME();
Serial.println("");
SPEED();
Serial.println("");
COURSE();
void COURSE(){
  course=gps.course()/100;
  Serial.print("COURSE: ");
  Serial.println(course);
void SPEED(){
  speed=gps.speed()*0.0115078;
  Serial.print("SPEED: ");
  Serial.println(speed);
void TIME(){
  Serial.print("TIME: ");
  Serial.print(((time/1000000)+16)%12);
  Serial.print(":");
  if(((time%1000000)/10000)<10){
    Serial.print("0");
  Serial.print((time%1000000)/10000);
  Serial.print(":");
  Serial.print((time%10000)/100);
void LAT(){
//  DEG=lat/1000000;
//  MIN1=(lat/10000)%100;
//  MIN2=lat%10000;
    int a=lat/1000000;
    int c=lat%1000000;
  Serial.print("LAT:");
  Serial.print(a);
  Serial.print(".");
  if(c<100000){
    Serial.print("0");
    if(c<10000){
      Serial.print("0");
      if(c<1000){
        Serial.print("0");
        if(c<100){
          Serial.print("0");
          if(c<10){
            Serial.print("0");
  Serial.print(c);
//  Serial.print(DEG);
//  Serial.prin(",");
//  Serial.print(MIN1);
//  Serial.print(".");
//  Serial.print(MIN2);
//  Serial.print("'   ");
void LON(){                        //Longitude state
//  DEG=lon/1000000;
//  MIN1=(lon/10000)%100;
//  MIN2=lon%10000;
    int b=lon/1000000;
    int d=lon%1000000;
  Serial.print("LON:");
  Serial.print(b);
  Serial.print(".");
  if(d<100000){
    Serial.print("0");
    if(d<10000){
      Serial.print("0");
      if(d<1000){
        Serial.print("0");
        if(d<100){
          Serial.print("0");
          if(d<10){
            Serial.print("0");
  Serial.print(d);
