Topic: CNC X motor not moving (Read 1 time) previous topic - next topic
Marciokoko
Aug 31, 2019, 07:57 pm Last Edit: Aug 31, 2019, 08:02 pm by Marciokoko
Im using UniversalGCodeSender in Java to control my cnc shield with 2 axes.  At some point i remember both motors moving fine.  But right now that I actually wanted to calibrate it, the X-axis motor makes the noise like its moving, but it doesnt move. Where do i start debugging, could it be a software issue or definitely hardware?  The motor looks fine and so does the gear part.
At config start I get this in the console.
Code: [Select]
$0 = 10    (step pulse, usec)
$1 = 25    (step idle delay, msec)
$2 = 0    (step port invert mask:00000000)
$3 = 0    (dir port invert mask:00000000)
$4 = 0    (step enable invert, bool)
$5 = 0    (limit pins invert, bool)
$6 = 0    (probe pin invert, bool)
$10 = 3    (status report mask:00000011)
$11 = 0.010    (junction deviation, mm)
$12 = 0.002    (arc tolerance, mm)
$13 = 0    (report inches, bool)
$20 = 0    (soft limits, bool)
$21 = 0    (hard limits, bool)
$22 = 0    (homing cycle, bool)
$23 = 0    (homing dir invert mask:00000000)
$24 = 25.000    (homing feed, mm/min)
$25 = 500.000    (homing seek, mm/min)
$26 = 250    (homing debounce, msec)
$27 = 1.000    (homing pull-off, mm)
$100 = 250.000    (x, step/mm)
$101 = 250.000    (y, step/mm)
$102 = 250.000    (z, step/mm)
$110 = 500.000    (x max rate, mm/min)
$111 = 500.000    (y max rate, mm/min)
$112 = 500.000    (z max rate, mm/min)
$120 = 10.000    (x accel, mm/sec^2)
$121 = 10.000    (y accel, mm/sec^2)
$122 = 10.000    (z accel, mm/sec^2)
$130 = 200.000    (x max travel, mm)
$131 = 200.000    (y max travel, mm)
$132 = 200.000    (z max travel, mm)
Marciokoko
#1
Aug 31, 2019, 08:21 pm Last Edit: Aug 31, 2019, 08:29 pm by Marciokoko
nevermind...got it working.  took the motor out and it worked fine, something must have gotten stuck upon reassembly the first time.
Actually I found that upon reassembly it happened again, and discovered this part of the motor gets pressed against the assembly and caused the issue.
