Topic: wattage consumption (Read 323 times) previous topic - next topic
tjones9163
Sep 02, 2019, 08:11 pm Last Edit: Sep 02, 2019, 08:12 pm by tjones9163
Hello, I live in West Palm Beach, FL. We have a  hurricane heading close by us and in case I lose power I am trying to see how many devices I can run on my Inverter and my question is:
1) My Xbox one's power supply says it uses 12v at 17.9A.
Then under that, it says 250wh.
When i multiply 12 times 17.9 i get = 214 w?? Those numbers don't exactly add up.
2) Then, when i looked it up online here it says that while playing a video game it draws 112 watts.
So i am utterly confused, can someone please help.
MK1888
17.9A isn't how much current it outputs.  The current is determined by the load.  If you have nothing connected to it, it outputs exactly zero amps.  And, apparently, playing a video game draws about 10 amps.  It can output *up to* 17.9A, beyond which maybe a fuse blows.
And the 12V may not be fully regulated.  It may be, but it may not.
SteveMann
#2
Sep 02, 2019, 08:24 pm Last Edit: Sep 02, 2019, 08:24 pm by SteveMann
The power supply PROVIDES 12V up to 17.9A, and consumes 250W from the wall.  The difference of 250-214 means your power supply is 85.6% efficient. Typical of switching power supplies.
I am usually so far out of the box that most people don't know what I am talking about.
Please do not ask for help by PM. I will not respond.
If you need help, post a question on the appropriate forum.
raschemmel
#3
Sep 02, 2019, 08:26 pm Last Edit: Sep 02, 2019, 08:27 pm by raschemmel
You're confusing the power supply ratings with the load (Xbox) ratings. They are totally different things.
Hello !
The power supply is NOT the Xbox !
tjones9163
So if i am using wattage calculations for an inverter, do i use the 150w that the xbox use's? or the 250w consumed from the wall?
raschemmel
#5
Sep 02, 2019, 09:19 pm Last Edit: Sep 02, 2019, 09:21 pm by raschemmel
As already stated , the 250W is not the xbox power consumption !
It is the power supply MAXIMUM RATING.
The xbox does not consume that much.
If you're cslculating loads then look at the LOAD (XBOX) NOT the supply.
jackrae
You have a potentially destructive hurricane threatening and your prime concern is whether you can play a game or not ?
raschemmel
Quote
I don't know what you do to kill time during a hurricane but obviously the OP has his priorities straight...
tjones9163
ya, first of all, you don't know any of the details, my parents already have generators for the a.c, fridge and lights and i have my own 2000w generator,
so why do you shut your mouth on things that you have no clue.
raschemmel
Quote
That attitude is not going to go over well with the Moderators...
TomGeorge
#10
Sep 03, 2019, 08:21 am Last Edit: Sep 03, 2019, 08:27 am by TomGeorge
I think the INPUT parameter is  the more important.
In this case 110V at 4.19A = 110 * 4.19 = 540W  input.
That would be the maximum power consumption.
Tom.. :)
PS, As for the remark about priorities, if you have kids then this device will be invaluable not during the hurricane but after, when for a time, it will be dangerous to go play outdoors.
Everything runs on smoke, let the smoke out, it stops running....
tjones9163
Tom.. :)
Thank you for the reply, to make sure, so if i have a 2000w inverter then the xbox accounts for 540w leaving me with 1460w ( I aware that you dont always get the full wattage of the inveter)??
If that is the case, then why is the xbox one says it only use 112 watts?
Thanks again.
TomGeorge
#12
Sep 03, 2019, 08:53 am Last Edit: Sep 03, 2019, 08:54 am by TomGeorge
If XBox itself consumes 112Watts.
Then the power supply being capable of 540W means if there are any accessories that can be connected to the XBox system, then it will have the capacity to safely power them as well.
It may be worth looking around for a plug in energy meter of some sort.
Google    plug in power meter
I have one and it takes the guess work out of doing load measurements on domestic appliances.
Tom.. :)
MarkT
This is AC, the rms current times the rms voltage is not the power, its the apparent power.  Real power can be a lot less than apparent power for a reactive load.
The maximum current draw given is probably the startup inrush current, not the steady current consumption
anyway.  The reason its given is to size the circuit and fuse appropriately, not as an indication of power consumption.
The label erroneously says "Wh" instead of "W" for power consumption and standby power consumption.  That
doesn't inspire any confidence in the numbers on the label to me.
