Topic: stepper motor, inductive proximity sensor (Read 262 times) previous topic - next topic
TheWarrior123
good afternooon everyone, i have a trouble in my project, so basically, my 28byj-48 stepper motor just keeps rotating continuously and doesnt stop, what i want to do is that... when the inductive proximity sensor senses a metal, the stepper motor will rotate on a certain degree and back to its original position, and when the sensor is not sensing something, the motor will not do anything.... when i uploaded the code, the motor starts moving even if the sensor does not sense anything
here's the code
#include <Stepper.h>
double stepsPerRevolution = 600;
Stepper myStepper(stepsPerRevolution, 8, 10, 9, 11);
const int analogPin = A0;
const int threshold = 400;
  myStepper.setSpeed(30);
  pinMode(A0,INPUT);
    int analogValue = analogRead(analogPin);
   if (analogValue < threshold)
  myStepper.step(stepsPerRevolution);
  delay(1);
  myStepper.step(-stepsPerRevolution);
  delay(1);
wildbill
TomGeorge
#2
Sep 03, 2019, 02:35 pm Last Edit: Sep 03, 2019, 02:35 pm by TomGeorge
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html .
Then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
What model Arduino are you using?
What are you driving the stepper motor with?
Link to specs/data please.
Thanks.. Tom.... :)
Everything runs on smoke, let the smoke out, it stops running....
Paul_KD7HB
The inductive proximity sensors I have give a digital pulse output once when a steel gear tooth becomes present. What does your sensor do?
Paul
MarkT
Why are you attempting to do a whole revolution upon detecting the threshold?
Surely you should step one step unless the threshold is reached, in which case you stop issuling steps?
