Topic: 8x8 modules interfacing issue (RGB led ws2811 module) (Read 273 times) previous topic - next topic
Kashi-8050
Hi !
I designed 8x8 sized module RGB led ws2811 this module working properly but when i go for adding extra modules i getting issue, so i want to add this modules so my code is not working for extra modules. please help me
Code: [Select]
 #include <FastLED.h>
#include <SPI.h>
#include <SD.h>
#define NUM_LEDS 64 // LED number
#define DATA_PIN 6    // your data arduino pin
#define CHIPSET WS2811  // your LED chip type
#define CMD_NEW_DATA 1
unsigned char x = 8; // matrix x size
unsigned char y = 8; // matrix y size
File fxdata;
CRGB leds[NUM_LEDS];
  FastLED.addLeds<CHIPSET, DATA_PIN, GRB>(leds, NUM_LEDS); //see doc for different LED strips
//  Serial.begin(BAUD_RATE); // when using Glediator via usb
  for(int y = 0 ; y < NUM_LEDS ; y++)
    leds[y] = CRGB::Black; // set all leds to black during setup
  FastLED.show();
  pinMode(10, OUTPUT); // CS/SS pin as output for SD library to work.
  digitalWrite(10, HIGH); // workaround for sdcard failed error...
  if (!SD.begin(4))
    Serial.println("sdcard initialization failed!");
    return;
  Serial.println("sdcard initialization done.");
  // test file open
  fxdata = SD.open("myanim.dat");  // read only
  if (fxdata)
    Serial.println("file open ok");
    fxdata.close();
int serialGlediator ()
  while (!Serial.available()) {}
  return Serial.read();
  if (fxdata)
  while (fxdata.available())
    fxdata.readBytes((char*)leds, NUM_LEDS*3);
    ledSort(2);  //1-4 possible, set your first LED's position. Change the number: 1=TL(top left),2=TR(top right),3=BL(bottom left),4=BR(bottom right)
     FastLED.show();
    delay(50); // set the speed of the animation. 20 is appx ~ 500k bauds
  // close the file in order to prevent hanging IO or similar throughout time
  fxdata.close();
int ledSort (int modus) { //1=TL,2=TR,3=BL,4=BR, this function will rearrange the led array ;-)
    CRGB tmp[x];
    if(modus == 3 || modus == 4) {
for(int i = 0; i < (y / 2);i++) {
    for(int j = 0; j < x;j++) {
tmp[j] = leds[i * x + j];
leds[i * x] = leds[(y - i - 1) * x];
leds[(y - i - 1) * x] = tmp[j];
     if(modus == 1 || modus == 3) {
       for(int i = 1; i < y; i = i + 2) {
       for(int j = x; j > 0;j--) {
        tmp[(x - j)] = leds[i * x + j - 1];
    leds[i * x + j] = tmp[j];
     if(modus == 2 | modus == 4) {
      for(int i = 0; i < y; i = i + 2) {
      return 1;
Grumpy_Mike
So how have you wired it up? What power supply do you have? Do you have good supply decoupling?
