Topic: sensor 014A wind speed and 024A wind direction wiring (Read 181 times) previous topic - next topic
sanusi
Hi can anyone help me how to wire these two sensors to arduino?
I've been searching for the manuals, but i still don't understand how to wire these to the arduino.
014A manual: https://s.campbellsci.com/documents/ca/manuals/014a_man.pdf
024A manual: https://s.campbellsci.com/documents/ca/manuals/024a_man.pdf
thanks in advance :)
wvmarle
014A: specifications on p.4 tell it's a reed contact; page B-1 gives the wiring.
White and clear to GND; signal to input pin. Enable the internal pull-up and start counting.
024A: page 9, heading 7.3 gives the wiring. Again it's really simple. White and clear to GND; red to an analog input; black to 5V. Your analog reading will be about 0-512, check your setup for the actual maximum and minimum. A simple calculation gives you the position of the pot, and that gives you the wind direction.
Quality of answers is related to the quality of questions. Good questions will get good answers. Useless answers are a sign of a poor question.
