Topic: ATMEGA328p AU can't upload bootloader (Read 508 times) previous topic - next topic
ccurran689
I have been burning bootloaders onto blank atmega328p-pu chips. When I try to repeat the same process on a ATMEGA328p-AU SMD chip I get this error;
avrdude: Device signature = 0x000000
avrdude: Yikes!  Invalid device signature.
        Double check connections and try again, or use -F to override
        this check.
I have re-wired the parts 100's of times without avail, the same setup works on the PU chip with no issues. I have tried using lillypad and another board configuration which I downloaded from this fourm which is apparently designed for the SMD. My circuit is using the UNO to upload the bootloader and I am using the pin configuration from the arduino to breadboard instructional from the arduino page. I have tried with and without a 16Mhz clock (with 22pf capacitors) but I still get the same error. I am connecting to the SMD pins using a TQfp32 socket https://www.waveshare.com/qfp32-to-dip32.htm.
Any help with this would be greatly appreciated as I am beginning to lose the plot trying to solve this.
full error code:
Arduino: 1.8.9 (Windows 10), Board: "Arduino/Genuino Uno"
avrdude: Version 6.3-20171130
        Copyright (c) 2007-2014 Joerg Wunsch
        System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
        Using Port                    : COM8
        Using Programmer              : arduino
        Overriding Baud Rate          : 19200
        AVR Part                      : ATmega328P
        Chip Erase delay              : 9000 us
        PAGEL                         : PD7
        BS2                           : PC2
        RESET disposition             : dedicated
        RETRY pulse                   : SCK
        serial program mode           : yes
        parallel program mode         : yes
        Timeout                       : 200
        StabDelay                     : 100
        CmdexeDelay                   : 25
        SyncLoops                     : 32
        ByteDelay                     : 0
        PollIndex                     : 3
        PollValue                     : 0x53
        Memory Detail                 :
                                 Block Poll               Page                       Polled
          Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
          eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
          flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
          lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
          hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
          efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
          lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
          calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
          signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
        Programmer Type : Arduino
        Description     : Arduino
        Hardware Version: 2
        Firmware Version: 1.18
        Topcard         : Unknown
        Vtarget         : 0.0 V
        Varef           : 0.0 V
        Oscillator      : Off
        SCK period      : 0.1 us
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x000000 (retrying)
Reading | ################################################## | 100% 0.01s
An error occurred while uploading the sketch
        this check.
avrdude done.  Thank you.
ccurran689
I have now got a USB asp and I am recieving this error:
avrdude: error: programm enable: target doesn't answer. 1
avrdude: initialization failed, rc=-1
         this check.
Any help would be greatly appreciated, can't make any progress.
Budvar10
        Using Port                    : COM8
Arduino as ISP needs either the programmer type stk500v1 or to place large capacitor ~10uF between RESET and GND on the UNO which is a programmer.
Clock source on the target can be needed. Fuses are programmed first before the bootloader and if there is setting for external clock then ATmega stops working until an external clock source is connected. Raw ATmega is shipped with an internal clock source set.
Chinese USBasp need to set slow SCK with jumper if the chip has slow clock source like by default. However, it is highly likely that the pins for jumper are not soldered.
Arduino clone with ATmega1284P   http://forum.arduino.cc/index.php?topic=277260.0
pert
Note that in the newly released Arduino AVR Boards 1.8.1, the protocol of the Arduino as ISP programmer was changed back to stk500v1 from arduino. A new programmer named "Arduino as ISP (ATmega32U4)" was added that still uses the arduino protocol, which is required to use the ATmega32U4-based boards as an Arduino as ISP on Windows.
Juraj
#4
Sep 20, 2019, 02:02 pm Last Edit: Sep 20, 2019, 02:03 pm by Juraj
Per, I missed the release of 1.8.1 (or I forgot about it). I think I recommended some weeks ago to someone with the 'segmentation fault' error to revert to 1.6.21 from IDE default 1.6.23. Is the 'segmentation fault' error resolved in 1.8.1?
Budvar10
@pert
I am not using the newest release but I already noticed this change in some topic and I thought so. Thank you for highlights.
