Topic: SerLCD Troubles (Read 966 times) previous topic - next topic
paimonsoror
I just recently got an Arduino Uno, the Can-bus Shield, a SerLCD backpack from sparkfun, and a 20x4 LCD screen
I just went through the update of making sure that the latest USB firmware was installed on the Uno.  I used the tutorial that had me go into DFU mode, and use Flip.  That install went without a hitch.
My biggest issue is trying to install the SerLCD hex file.  Here is what I tried:
Quote
C:\Users\core2quad\Desktop\uno_programming_with_avrdude>avrdude -p m328p -c arduino -P COM10 -b 115200 -U flash:w:serlcd.hex
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude: Device signature = 0x1e950f
avrdude: NOTE: FLASH memory has been specified, an erase cycle will be performed
         To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file "serlcd.hex"
avrdude: input file serlcd.hex auto detected as Intel Hex
avrdude: writing flash (16400 bytes):
Writing | ################################################## | 100% 2.09s
avrdude: 16400 bytes of flash written
avrdude: verifying flash memory against serlcd.hex:
avrdude: load data flash data from input file serlcd.hex:
avrdude: input file serlcd.hex contains 16400 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 3.20s
avrdude: verifying ...
avrdude: verification error, first mismatch at byte 0x0980
         0xff != 0xf8
avrdude: verification error; content mismatch
avrdude: safemode: Fuses OK
avrdude done.  Thank you.
Just to try to make sure I can actually install a simple Blink test, I compiled and installed Blink via the arduino software, as well as through a hex file from avrdude.  Both worked fine.  Is there something I am missing here??
