Topic: Connect headphones to arduino (Read 794 times) previous topic - next topic
CodenameXX
So I've been looking at building a synth with an arduino. I read a lot of articles that were telling you can't connect headphones to the arduino because of the input impedance and the square shape of the signal.
I came across this article (link below), which basically calculates a wave and sends it out as a fast PWM signal. By connecting an RC-filter, they get an analog signal that varies between 0-5V.
https://makezine.com/projects/make-35/advanced-arduino-sound-synthesis/
Would it be possible to connect headphones to the output of the filter? Or will I still have problems?
Kind regards
Grumpy_Mike
#1
Sep 06, 2019, 11:30 am Last Edit: Sep 06, 2019, 11:31 am by Grumpy_Mike
The output of that filter is high impedance, if you connect your low impedance headphones to that the signal will collapse.
High impedance headphones are a thing of the past, you have to get them from vintage shops these days.
What is wrong with using an amplifier?
MarkT
That transistor circuit driving an 8 ohm speaker is a very cheap/cheerful solution to the impedance issue I suppose.  Puts DC bias on the speaker though which could be fatal to headphone drivers alas...
Amplifier chips are the way to go really, yes.
