I tried it on my laptop and got the same error. I'm trying to compile the sample sketch that came with xbee.h. I got it from
http://code.google.com/p/xbee-arduino/. The sample sketch is called Series1_IoSamples
I uploaded a screen shot of my Arduino directories.
The errors I'm getting are:
Series1_IoSamples.cpp:20:18: error: XBee.h: No such file or directory
Series1_IoSamples.cpp:21:27: error: NewSoftSerial.h: No such file or directory
Series1_IoSamples:40: error: 'NewSoftSerial' does not name a type
Series1_IoSamples:42: error: 'XBee' does not name a type
Series1_IoSamples:44: error: 'Rx16IoSampleResponse' does not name a type
Series1_IoSamples.cpp: In function 'void setup()':
Series1_IoSamples:49: error: 'xbee' was not declared in this scope
Series1_IoSamples:51: error: 'nss' was not declared in this scope
Series1_IoSamples.cpp: In function 'void loop()':
Series1_IoSamples:56: error: 'xbee' was not declared in this scope
Series1_IoSamples:61: error: 'RX_16_IO_RESPONSE' was not declared in this scope
Series1_IoSamples:62: error: 'ioSample' was not declared in this scope
Series1_IoSamples:64: error: 'nss' was not declared in this scope
Series1_IoSamples:103: error: 'nss' was not declared in this scope
Series1_IoSamples:108: error: 'nss' was not declared in this scope
Here's the sketch:
* Copyright (c) 2009 Andrew Rapp. All rights reserved.
* This file is part of XBee-Arduino.
* XBee-Arduino is free software: you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation, either version 3 of the License, or
* (at your option) any later version.
* XBee-Arduino is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with XBee-Arduino. If not, see <http://www.gnu.org/licenses/>.
#include "XBee.h"
#include "NewSoftSerial.h"
This example is for Series 1 XBee Radios only
Receives I/O samples from a remote radio with 16-bit addressing.
The remote radio must have IR > 0, at least one digital or analog input enabled
and DL set to the 16-bit address of the receiving XBee (the one connected to the Arduino).
This example uses the NewSoftSerial library to view the XBee communication. I am using a
Modern Device USB BUB board (http://moderndevice.com/connect) and viewing the output
with the Arduino Serial Monitor.
You can obtain the NewSoftSerial library here http://arduiniana.org/libraries/NewSoftSerial/
// Define NewSoftSerial TX/RX pins
// Connect Arduino pin 9 to TX of usb-serial device
uint8_t ssRX = 9;
// Connect Arduino pin 10 to RX of usb-serial device
uint8_t ssTX = 10;
// Remember to connect all devices to a common Ground: XBee, Arduino and USB-Serial device
NewSoftSerial nss(ssRX, ssTX);
XBee xbee = XBee();
Rx16IoSampleResponse ioSample = Rx16IoSampleResponse();
// 64-bit response is same except api id equals RX_64_IO_RESPONSE and returns a 64-bit address
//Rx64IoSampleResponse ioSample = Rx64IoSampleResponse();
xbee.begin(9600);
// start soft serial
nss.begin(9600);
//attempt to read a packet
xbee.readPacket();
if (xbee.getResponse().isAvailable()) {
// got something
if (xbee.getResponse().getApiId() == RX_16_IO_RESPONSE) {
xbee.getResponse().getRx16IoSampleResponse(ioSample);
nss.print("Received I/O Sample from: ");
nss.println(ioSample.getRemoteAddress16(), HEX);
nss.print("Sample size is ");
nss.println(ioSample.getSampleSize(), DEC);
if (ioSample.containsAnalog()) {
nss.println("Sample contains analog data");
if (ioSample.containsDigital()) {
nss.println("Sample contains digtal data");
for (int k = 0; k < ioSample.getSampleSize(); k++) {
nss.print("Sample ");
nss.print(k + 1, DEC);
nss.println(":");
for (int i = 0; i <= 5; i++) {
if (ioSample.isAnalogEnabled(i)) {
nss.print("Analog (AI");
nss.print(i, DEC);
nss.print(") is ");
nss.println(ioSample.getAnalog(i, k));
for (int i = 0; i <= 8; i++) {
if (ioSample.isDigitalEnabled(i)) {
nss.print("Digtal (DI");
nss.print(i, DEC);
nss.print(") is ");
nss.println(ioSample.isDigitalOn(i, k));
else {
nss.print("Expected I/O Sample, but got ");
nss.print(xbee.getResponse().getApiId(), HEX);
else if (xbee.getResponse().isError()) {
nss.print("Error reading packet. Error code: ");
nss.println(xbee.getResponse().getErrorCode());
