Topic: Debouncing multiple buttons using schmitt trigger (Read 1 time) previous topic - next topic
Kuusou
I was hoping that someone on these forums could double check my schematic to ensure this will work properly on my PCB.
I'm trying to debounce/deglitch three buttons using a schmitt trigger and rc circuit. I'm using a 74HC14. My question is, can I use R5(10k resistor) for all three buttons as a pull up resistor or does each button need to have its own? The image is rather small but that resistor is running to the 5v supply. I normally had the buttons attached to the trinket and used its built in pullup resistors but since I have to run through the 74HC14 on this design I can't use that feature. I just want to be sure that using this design will give me the desired result before I order the pcb's and wait several weeks for them to get here only to find I've made a mistake somewhere.
My other question is whether this rc circuit will have enough filtering to debounce the button or should I change the resistor or cap values to adjust the time? Thanks for your time!
septillion
#1
Sep 08, 2019, 09:59 pm Last Edit: Sep 08, 2019, 09:59 pm by septillion
Do I need to say more?
Why? Who's giving you that awkward requirement?
Use fricking code tags!!!!
I want x => I would like x, I need help => I would like help, Need fast => Go and pay someone to do the job...
NEW Library to make fading leds a piece of cake
https://github.com/septillion-git/FadeLed
Kuusou
#2
Sep 08, 2019, 10:07 pm Last Edit: Sep 08, 2019, 10:10 pm by Kuusou
I'm just trying to follow this schematic
I'm not sure what the highlighted red line means exactly, sorry i'm rather new to all this so i'm sorry if that's a stupid question.
No one is giving me that req, just that my understanding is that it needs to run through a schmitt trigger to properly debounce it and i'm not sure how i would use the pullup resistors on the trinket with this set up.
septillion
Why? Just connect it to the Arduino :)
It shows a connection which is made when the "bright" button is pressed. Do you want that connection ;)
Kuusou
Well before the buttons were attached to the trinket but I need to properly debounce/deglitch them using hardware. I'm aware of button debouncing in software but that's not an option for me. The buttons trigger interrupts within my software and as a result I'm not able to properly debounce them so i'm trying to use a hardware solution instead.
I see what you're saying, so in this case I'd need each button to have its own resistor to avoid that.
Kuusou
#5
Sep 08, 2019, 10:21 pm Last Edit: Sep 08, 2019, 10:23 pm by Kuusou
So this should resolve that issue correct?
Is it possible to connect the buttons to the arduino and use the internal resistors and still get the debounce effect from the schmitt trigger???
septillion
Now there is your problem ;) We humans push the buttons. We humans are dead slow. Interrupts are for fast things. Aka, an interrupt is ALWAYS* the wrong choice for a button ;)
Correct, classic newbie brain fart ;) Don't blame you, made them in the past as well.
But it also shows to me you don't have a real clue why you do this. So my suggestion, drop the interrupt, just poll and debounce in software, saves you the hardware and easier to change :)
PS Also, don't be evil and draw GND down. Only evil people drop it upwards ;)
* With the exception if it needs to wake the uC from sleep.
Kuusou
#7
Sep 08, 2019, 10:32 pm Last Edit: Sep 08, 2019, 10:38 pm by Kuusou
I'm aware this probably looks like the XY problem.
I'm aware of the fact that its bad practice to use interrupts with buttons and have read a lot about it at this point. However my particular case (i need you to trust me on this) I need to have the interrupts attached to the buttons. A hardware solution is the only one I have. My program has some 13 different looping functions that I need to be able to switch between whenever a button is pressed. I was unable to find a better solution than to use interrupts and no one on this forum was able to help point me in another direction, other than to refer me to blink without delay, which didn't help me in my case or at least make me understand a better way to do it. At this point my program is already written and a hardware solution is the much easier option.
In this case, is my schematic as laid out as well as It can be?
Hahaha I wasn't aware evil people did that! I'll have to avoid that in the future
septillion
Sorry, I just can't ;) To me it points to a design flaw elsewhere ;)
One thing I'm missing, the 100nF for the chip itself! ;) Every chip wants a decoupling cap close by. Besides that and the evilness it should work.
Kuusou
I'm not sure I following you on this. What do you mean? Is the 100nF too weak? Wrong type of cap?
septillion
Noting to do with the current caps, but something that applies for all chips, they want a 100nF ceramic cap over the power rail close by (aka, right next to the IC) so they have a clean power supply :)
Kuusou
So something like this?
attached like C4?
raschemmel
Yeah, it's close on the schematic but he means physically close to the IC, as close as possible.
Kuusou
I've been reading up on that, looks like my schematic above is slightly wrong though because the cap should go to ground.
raschemmel
Correct.
I didn't notice that it was connected to Vcc.
