Topic: trouble following library linking in general... but specifically with TimeLib.h  (Read 228 times) previous topic - next topic
the_orn
Running Arduino 1.8.9 for ESP8266 (2.5.2)
I'm trying to use TimeLib (//https://github.com/PaulStoffregen/Time) and Timezone (//https://github.com/JChristensen/Timezone).
But I'm running into linker problems. Output:
Code: [Select]
c:/users/rudy/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-3-20ed2b9/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: libraries\Timezone\Timezone.cpp.o:(.text._ZN8Timezone8toTime_tE14TimeChangeRulei+0x8): undefined reference to `makeTime(tmElements_t const&)'
c:/users/rudy/appdata/local/arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-3-20ed2b9/bin/../lib/gcc/xtensa-lx106-elf/4.8.2/../../../../xtensa-lx106-elf/bin/ld.exe: libraries\Timezone\Timezone.cpp.o: in function `Timezone::toTime_t(TimeChangeRule, int)':
C:\Users\Rudy\Documents\Arduino\libraries\Timezone\src/Timezone.cpp:200: undefined reference to `makeTime(tmElements_t const&)'
I'm not sure why the linker isn't finding makeTime. I put pragma messages in to show that TimeLib.h is being include (it is) and that Time.cpp is compiling (it is).
The simplest program that replicates the link error is here:
Code: [Select]
#include <Timezone.h>
TimeChangeRule myDST = {"CDT", Second, Sun, Mar, 2, -240};    // Daylight time = UTC - 5 hours
TimeChangeRule mySTD = {"CST", First, Sun, Nov, 2, -300};     // Standard time = UTC - 6 hours
Timezone myTZ(myDST, mySTD);
  myTZ.locIsDST((time_t) 0);
Thanks for any help!!
Rudy
the_orn
Update. Have downgraded to Arduino to 1.8.1. And the ESP8266 hardware to 2.2.0. I did this to try to replicate the results gotten here: https://www.arduinoslovakia.eu/blog/2017/7/esp8266---ntp-klient-a-letny-cas?lang=en
And their code is compiling with the same undefined reference:
Code: [Select]
the_orn
Update and partial solution:
Okay, I found that the Time.cpp and TimeLib.h declarations differed:
Time.cpp:
Code: [Select]
time_t makeTime(tmElements_t &tm){
TimeLib.h (but NOT Time.h, which is theoretically identical...)
Code: [Select]
time_t makeTime(const tmElements_t &tm);  // convert time elements into time_
I removed the const and it compiled.
That actually makes sense to me, though I'm surprised it wasn't found sooner. On the off chance though, is there a configuration step that I missed?
I'll submit as a bug report to the Time project...
