Topic: Eagle auto router keeps routing on the bottom layer (Read 290 times) previous topic - next topic
liuzengqiang
I must have screwed up a setting in EAGLE. It keeps routing on the bottom layer with vias instead of making a simple top-layer trace:
My settings didn't prefer bottom over top, I think and via costs something, not nothing. I get these vias all over my board.
Serial LCD keypad panel,phi_prompt user interface library,SDI-12 USB Adapter
liuzengqiang
I didn't give a routing preferred direction for either layer. I used * for both layers. I now forced it to do - on top layer and | on bottom layer. I don't think it's the final solution. If my top trace is supposed to be vertical then the autorouter may still want to do the routing on the bottom layer.
SteveMann
I am very new to Eagle and not qualified to offer assistance, but it looks like the autorouter is routing around a value?  Did you make that part and accidentally put the value on the top layer?
liuzengqiang
That wasn't the case. The value is on silk screen layer.
srnet
You might get a quicker answer in the Eagle support forums.
http://www.50dollarsat.info/
http://www.loratracker.uk/
liuzengqiang
It's the version that will get them laughing. They're on EAGLE 9.x with subscription and I'm on EAGLE 6.6.0 perpetual license. Will try though. Thanks.
