Topic: Arduino ide ver.1.8.10 for windows 10 keep crashing when i try to save project (Read 225 times) previous topic - next topic
FendiArdig
Pls help me why did this app keep crashing when i click save or upload?
pert
Please do this:
  • Start the Windows command line "cmd".
  • Run the program arduino_debug.exe that you will find in the Arduino IDE installation folder from the command line.
  • After it crashes, copy the output that's printed to the cmd window and paste it here USING CODE TAGS (</> button on the toolbar).
Hopefully that will give us some information we can use to help you with the problem.
FendiArdig
I have done what u suggest to me but i didnt see any output that's printed to the cmd window, so i copied the text inside hs_err_pid3436.log to here, can u help me thru this trouble here
# A fatal error has been detected by the Java Runtime Environment:
#  EXCEPTION_IN_PAGE_ERROR (0xc0000006) at pc=0x74d5e2fe, pid=3436, tid=0x00001f98
# JRE version: Java(TM) SE Runtime Environment (8.0_191-b12) (build 1.8.0_191-b12)
# Java VM: Java HotSpot(TM) Client VM (25.191-b12 mixed mode windows-x86 )
# Problematic frame:
# C  [COMDLG32.dll+0x6e2fe]
# Failed to write core dump. Minidumps are not enabled by default on client versions of Windows
# If you would like to submit a bug report, please visit:
#   http://bugreport.java.com/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
---------------  T H R E A D  ---------------
Current thread (0x2545e400):  JavaThread "AWT-Windows" daemon [_thread_in_native, id=8088, stack(0x25c30000,0x25c80000)]
siginfo: ExceptionCode=0xc0000006, ExceptionInformation=0x00000008 0x74d5e2fe 0xc000009c
Registers:
EAX=0x00000000, EBX=0x00000000, ECX=0x254a3798, EDX=0x00000000
ESP=0x25c7de54, EBP=0x25c7de80, ESI=0x25c7f010, EDI=0x00000000
EIP=0x74d5e2fe, EFLAGS=0x00010246
Top of Stack: (sp=0x25c7de54)
0x25c7de54:   74d3d210 00000000 25c7f010 29c34854
0x25c7de64:   74d31936 74d317de 25c7de50 00000000
0x25c7de74:   25c7dea8 75b36030 afa8ddf5 25c7deb4
0x25c7de84:   74d44a61 25c7dea0 25c7deac 00000000
0x25c7de94:   74d28b80 29c34854 711bc770 00000000
0x25c7dea4:   25c7f010 00000000 25c7df2c afa8ddc1
0x25c7deb4:   25c7dee4 74d3d548 29c34854 00000000
0x25c7dec4:   74d28b80 00000001 74554a81 80004005
Instructions: (pc=0x74d5e2fe)
0x74d5e2de:
[error occurred during error reporting (printing registers, top of stack, instructions near pc), id 0xc0000006]
Register to memory mapping:
EAX=0x00000000 is an unknown value
EBX=0x00000000 is an unknown value
ECX=0x254a3798 is an unknown value
EDX=0x00000000 is an unknown value
ESP=0x25c7de54 is pointing into the stack for thread: 0x2545e400
EBP=0x25c7de80 is pointing into the stack for thread: 0x2545e400
ESI=0x25c7f010 is pointing into the stack for thread: 0x2545e400
EDI=0x00000000 is an unknown value
Stack: [0x25c30000,0x25c80000],  sp=0x25c7de54,  free space=311k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
C  [COMDLG32.dll+0x54a61]
C  [COMDLG32.dll+0x4d548]
C  [COMDLG32.dll+0x48dc7]
C  [COMDLG32.dll+0x3a8e1]
C  [COMDLG32.dll+0x1b215]
C  [COMDLG32.dll+0x1bafd]
C  [awt.dll+0x868cc]
C  0x00000018
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j  sun.awt.windows.WToolkit.eventLoop()V+0
j  sun.awt.windows.WToolkit.run()V+58
j  java.lang.Thread.run()V+11
v  ~StubRoutines::call_stub
---------------  P R O C E S S  ---------------
Java Threads: ( => current thread )
  0x2884d000 JavaThread "DestroyJavaVM" [_thread_blocked, id=4664, stack(0x021e0000,0x02230000)]
  0x26da0800 JavaThread "Timer-0" [_thread_blocked, id=3528, stack(0x29fb0000,0x2a000000)]
  0x26da1c00 JavaThread "TimerQueue" daemon [_thread_blocked, id=13356, stack(0x29d70000,0x29dc0000)]
  0x26da1000 JavaThread "Batik CleanerThread" daemon [_thread_blocked, id=8708, stack(0x28240000,0x28290000)]
  0x26da2400 JavaThread "AWT-EventQueue-0" [_thread_in_native, id=14612, stack(0x28060000,0x280b0000)]
  0x26da3400 JavaThread "AWT-Shutdown" [_thread_blocked, id=8596, stack(0x27b00000,0x27b50000)]
  0x26cb9400 JavaThread "JmmDNS pool-3-thread-1" [_thread_blocked, id=13648, stack(0x27fd0000,0x28020000)]
  0x26cb9000 JavaThread "JmDNS(GAHARU.local.).State.Timer" [_thread_blocked, id=14660, stack(0x27f40000,0x27f90000)]
  0x26cb5000 JavaThread "JmDNS(GAHARU.local.).Timer" daemon [_thread_blocked, id=4104, stack(0x27eb0000,0x27f00000)]
  0x26cb5800 JavaThread "SocketListener(GAHARU.local.)" daemon [_thread_in_native, id=2476, stack(0x27e20000,0x27e70000)]
  0x26c46c00 JavaThread "Multihomed mDNS.Timer" daemon [_thread_blocked, id=9392, stack(0x25ba0000,0x25bf0000)]
  0x26c3a400 JavaThread "cc.arduino.packages.discoverers.serial.SerialDiscovery" [_thread_blocked, id=13708, stack(0x27b90000,0x27be0000)]
=>0x2545e400 JavaThread "AWT-Windows" daemon [_thread_in_native, id=8088, stack(0x25c30000,0x25c80000)]
  0x2545d400 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=14208, stack(0x25b10000,0x25b60000)]
  0x24a93c00 JavaThread "Service Thread" daemon [_thread_blocked, id=14420, stack(0x250c0000,0x25110000)]
  0x24a9d800 JavaThread "C1 CompilerThread0" daemon [_thread_blocked, id=4932, stack(0x25030000,0x25080000)]
  0x24a9c000 JavaThread "Attach Listener" daemon [_thread_blocked, id=1676, stack(0x24fa0000,0x24ff0000)]
  0x24a9a400 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=15260, stack(0x24f10000,0x24f60000)]
  0x24a7b400 JavaThread "Finalizer" daemon [_thread_blocked, id=1656, stack(0x24d80000,0x24dd0000)]
  0x24a75800 JavaThread "Reference Handler" daemon [_thread_blocked, id=2628, stack(0x24cf0000,0x24d40000)]
Other Threads:
  0x24a60400 VMThread [stack: 0x24c60000,0x24cb0000] [id=11164]
  0x24a97000 WatcherThread [stack: 0x25150000,0x251a0000] [id=9276]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap:
 def new generation   total 39424K, used 33500K [0x04600000, 0x070c0000, 0x0f0a0000)
  eden space 35072K,  95% used [0x04600000, 0x066b71a0, 0x06840000)
  from space 4352K,   0% used [0x06840000, 0x06840000, 0x06c80000)
  to   space 4352K,   0% used [0x06c80000, 0x06c80000, 0x070c0000)
 tenured generation   total 87424K, used 32938K [0x0f0a0000, 0x14600000, 0x24600000)
   the space 87424K,  37% used [0x0f0a0000, 0x110cabd8, 0x110cac00, 0x14600000)
 Metaspace       used 24248K, capacity 25316K, committed 25472K, reserved 25984K
Card table byte_map: [0x04440000,0x04550000] byte_map_base: 0x0441d000
Polling page: 0x00a00000
CodeCache: size=32768Kb used=3726Kb max_used=3727Kb free=29041Kb
 bounds [0x023c0000, 0x02768000, 0x043c0000]
 total_blobs=2539 nmethods=2244 adapters=223
 compilation: enabled
FendiArdig
FendiArdig
