Topic: How to return to void loop() from sleep mode directly  (Read 229 times) previous topic - next topic
knee266
I have a sketch that needs to return to void loop()  from Powersave mode directly.
May I know how to do?
here is the simple sketch for explain:
attachInterrupt(0, wakeISR, LOW);  <<<<< I need return to loop() directly.
//if ADC value a,b no any change over 30 sec. then going to PowerSave mode.
while  (a<0 && b<0)
   energy.PowerSave();
//If the value of a and b have changes within 30 sec., continue run sketch
other sketch
DrAzzy
ATTinyCore for x4/x5/x61/x7/x8/x41/1634/828/x313 megaTinyCore for the megaavr ATtinies - Board Manager:
http://drazzy.com/package_drazzy.com_index.json
ATtiny breakouts, mosfets, awesome prototyping board in my store http://tindie.com/stores/DrAzzy
6v6gt
What MCU is it ?
and what is in  energy.PowerSave() ; ?
Anyway, if it is AVR based ( like Uno etc.), on waking the sketch starts at exactly after that point in the sketch at which it stopped. So, in your case, on waking, the sketch resumes at the statement after energy.PowerSave() .
Alfresco
You can do this using an empty Interrupt Service Routine(ISR).
knee266
Just have an empty ISR.
thanks for you help.
Here is a part of schematic.
The J1 is the function button and shared with interrupt pin.
When I press button ,the 328P will always be interrupted.
Can I ignore the external wakeup (INT0) when the CPU wakes up?
