Topic: ADXL345 interrupts problem (Read 118 times) previous topic - next topic
uzer123
i use the sparkfun library ADXL345 and the ADXL345 with Uno.
Everything works well (reading x,y,z and take events like tap, double tap etc). BUT when i go for the interrupts it can not work.
So, i did a button press interrupt to be sure interrupts are working. Then i replaced again with the ADXL345 INT1 but execution in serial monitor get stuck after i do some actions (like taping)..
Code: [Select]
 *  SparkFun_ADXL345_Example
 *  Triple Axis Accelerometer Breakout - ADXL345
 *  Hook Up Guide Example
 *  Utilizing Sparkfun's ADXL345 Library
 *  Bildr ADXL345 source file modified to support
 *  both I2C and SPI Communication
 *  E.Robert @ SparkFun Electronics
 *  Created: Jul 13, 2016
 *  Updated: Sep 06, 2016
 *  Development Environment Specifics:
 *  Arduino 1.6.11
 *  Hardware Specifications:
 *  SparkFun ADXL345
 *  Arduino Uno
#include <SparkFun_ADXL345.h>         // SparkFun ADXL345 Library
/*********** COMMUNICATION SELECTION ***********/
/*    Comment Out The One You Are Not Using    */
//ADXL345 adxl = ADXL345(10);           // USE FOR SPI COMMUNICATION, ADXL345(CS_PIN);
ADXL345 adxl = ADXL345();             // USE FOR I2C COMMUNICATION
/****************** INTERRUPT ******************/
/*      Uncomment If Attaching Interrupt       */
int interruptPin = 2;                 // Setup pin 2 to be the interrupt pin (for most Arduino Boards)
volatile int pressed = 0;
/******************** SETUP ********************/
/*          Configure ADXL345 Settings         */
void setup(){
 // pinMode(2, INPUT_PULLUP);
  Serial.begin(9600);                 // Start the serial terminal
  Serial.println("SparkFun ADXL345 Accelerometer Hook Up Guide Example");
  adxl.powerOn();                     // Power on the ADXL345
  adxl.setRangeSetting(16);           // Give the range settings
                                      // Accepted values are 2g, 4g, 8g or 16g
                                      // Higher Values = Wider Measurement Range
                                      // Lower Values = Greater Sensitivity
  adxl.setSpiBit(0);                  // Configure the device to be in 4 wire SPI mode when set to '0' or 3 wire SPI mode when set to 1
                                      // Default: Set to 1
                                      // SPI pins on the ATMega328: 11, 12 and 13 as reference in SPI Library
  adxl.setActivityXYZ(1, 0, 0);       // Set to activate movement detection in the axes "adxl.setActivityXYZ(X, Y, Z);" (1 == ON, 0 == OFF)
  adxl.setActivityThreshold(75);      // 62.5mg per increment   // Set activity   // Inactivity thresholds (0-255)
  adxl.setInactivityXYZ(1, 0, 0);     // Set to detect inactivity in all the axes "adxl.setInactivityXYZ(X, Y, Z);" (1 == ON, 0 == OFF)
  adxl.setInactivityThreshold(75);    // 62.5mg per increment   // Set inactivity // Inactivity thresholds (0-255)
  adxl.setTimeInactivity(10);         // How many seconds of no activity is inactive?
  adxl.setTapDetectionOnXYZ(0, 0, 1); // Detect taps in the directions turned ON "adxl.setTapDetectionOnX(X, Y, Z);" (1 == ON, 0 == OFF)
  // Set values for what is considered a TAP and what is a DOUBLE TAP (0-255)
  adxl.setTapThreshold(50);           // 62.5 mg per increment
  adxl.setTapDuration(15);            // 625 μs per increment
  adxl.setDoubleTapLatency(80);       // 1.25 ms per increment
  adxl.setDoubleTapWindow(200);       // 1.25 ms per increment
  // Set values for what is considered FREE FALL (0-255)
  adxl.setFreeFallThreshold(7);       // (5 - 9) recommended - 62.5mg per increment
  adxl.setFreeFallDuration(30);       // (20 - 70) recommended - 5ms per increment
  // Setting all interupts to take place on INT1 pin
  adxl.setImportantInterruptMapping(1, 1, 1, 1, 1);     // Sets "adxl.setEveryInterruptMapping(single tap, double tap, free fall, activity, inactivity);"
                                                        // Accepts only 1 or 2 values for pins INT1 and INT2. This chooses the pin on the ADXL345 to use for Interrupts.
                                                        // This library may have a problem using INT2 pin. Default to INT1 pin.
  // Turn on Interrupts for each mode (1 == ON, 0 == OFF)
  adxl.InactivityINT(1);
  adxl.ActivityINT(1);
  adxl.FreeFallINT(1);
  adxl.doubleTapINT(1);
  adxl.singleTapINT(1);
attachInterrupt(digitalPinToInterrupt(interruptPin), ADXL_ISR, CHANGE);   // Attach Interrupt
/****************** MAIN CODE ******************/
/*     Accelerometer Readings and Interrupt    */
void loop(){
  Serial.println("loop");
  // Accelerometer Readings
  int x,y,z;
  adxl.readAccel(&x, &y, &z);         // Read the accelerometer values and store them in variables declared above x,y,z
  // Output Results to Serial
  /* UNCOMMENT TO VIEW X Y Z ACCELEROMETER VALUES */
  //Serial.print(x);
  //Serial.print(", ");
  //Serial.print(y);
  //Serial.println(z);
  //ADXL_ISR();
  // You may also choose to avoid using interrupts and simply run the functions within ADXL_ISR();
  //  and place it within the loop instead.
  // This may come in handy when it doesn't matter when the action occurs.
     Serial.print("button pressed: ");
    Serial.println(pressed);
/********************* ISR *********************/
/* Look for Interrupts and Triggered Action    */
void ADXL_ISR() {
   pressed++;
  // getInterruptSource clears all triggered actions after returning value
  // Do not call again until you need to recheck for triggered actions
  byte interrupts = adxl.getInterruptSource();
  // Free Fall Detection
  if(adxl.triggered(interrupts, ADXL345_FREE_FALL)){
    //Serial.println("*** FREE FALL ***");
    //add code here to do when free fall is sensed
  // Inactivity
  if(adxl.triggered(interrupts, ADXL345_INACTIVITY)){
    //Serial.println("*** INACTIVITY ***");
     //add code here to do when inactivity is sensed
  // Activity
  if(adxl.triggered(interrupts, ADXL345_ACTIVITY)){
    //Serial.println("*** ACTIVITY ***");
     //add code here to do when activity is sensed
  // Double Tap Detection
  if(adxl.triggered(interrupts, ADXL345_DOUBLE_TAP)){
    //Serial.println("*** DOUBLE TAP ***");
     //add code here to do when a 2X tap is sensed
  // Tap Detection
  if(adxl.triggered(interrupts, ADXL345_SINGLE_TAP)){
   // Serial.println("*** TAP ***");
     //add code here to do when a tap is sensed
lesept
I think this line must not be commented
Code: [Select]
A force d'essayer on finit par réussir... Donc, plus ça rate, plus on a de chances que ça marche (proverbe Sharduinok).
uzer123
its not from the library.. i just added this to work with the button...
Danois90
The code in the sparkfun link uses RISING instead of CHANGE in attachInterrupt - may that be the culprit?
Instead of mocking what's wrong, teach what's right! ;)
When you get help, remember to thank the helper and give some karma!
Please, do NOT send me any private messages!!
uzer123
no..i left it from the button test also..sorry for confuse you..
here is the code from sparkfun example again, i changed only the things to make interrupt work..
(just to note that if i uncomment x,y,z i take the value normally)
is it common for interrupt pin of ADXL to be faulty?
Code: [Select]
 *  Arduino 1.6.11
 *  SparkFun ADXL345
 *  Arduino Uno
void setup(){
attachInterrupt(digitalPinToInterrupt(interruptPin), ADXL_ISR, RISING);   // Attach Interrupt
void loop(){
  int x,y,z;
  //Serial.print(x);
  //Serial.print(y);
  //ADXL_ISR();
void ADXL_ISR() {
  Serial.println("test_interrupt");
  // Inactivity
  // Activity
  // Tap Detection
lesept
I don't know, but you can comment the attachinterrupt and uncomment the call to ADXL_ISR in the loop.
uzer123
yes..thats the problem..i want to use interrupts because i want to deep sleep my MCU and wake it up when there is some action...
unless there is another way that i dont know..
Danois90
Try to remove all the serial communication from the ISR. If a lot of interrupts are triggered, the serial buffer may fill up and cause further serial communication to block and this may cause the arduino to hang. You may also want to try something like this for debugging purposes:
Code: [Select]
volatile unsigned long interrupts = 0;
  Serial.print("Interrupts = ");
  Serial.println(interrups);
void ADXL_ISR()
  interrupts++;
If this does not hang, try to fill in the other code line by line in order to figure out what causes the problem.
uzer123
#8
Sep 17, 2019, 09:01 pm Last Edit: Sep 18, 2019, 12:00 am by uzer123
i try to make the problem as simple as it can be..so i see that button interrupt with the same code (i have deleted all Serial.print lines from ISR) works fine.. i have Serial.println(analogRead(interruptPin)) and also used a multimeter. What i see is that INT1 of ADXL345 stays high no matter what..
I understand that it should go down or change even if i use the interrupt or not..
so..the problem now is why INT1 of ADXL345 doesnt produce any voltage change?
edit: search for hours..its definitely something strange with interrupt from the part of ADXL345..
i try to analogRead the INT1 of ADXL so i connect it to A0 and measure it:
if i do Serial.println(analogRead(A0)); inside ADXL_ISR() (which runs inside loop) and comment the rest of the code i take values around 686 - 687 all the time..IF i do the same put after Serial.println(analogRead(A0)); i leave   byte interrupts = adxl.getInterruptSource(); everything works as it should be: i take zeros..and when i tap or do other action i take a value like 686..
So, why is this happening and how i can use it for the creation of correct interrupt?
code with wrong values:
Code: [Select]
 *  Arduino 1.6.11
 *  SparkFun ADXL345
 *  Arduino Uno
//int interruptPin = 2;                 // Setup pin 2 to be the interrupt pin (for most Arduino Boards)
void setup(){
//attachInterrupt(digitalPinToInterrupt(interruptPin), ADXL_ISR, RISING);   // Attach Interrupt
void loop(){
  int x,y,z;
  //Serial.print(x);
  //Serial.print(y);
  //int xaxa = analogRead(A0);
  //if(xaxa >100) Serial.println(xaxa);
 ADXL_ISR();
void ADXL_ISR() {
  // Inactivity
  // Activity
  // Tap Detection
code with correct values:
the same but with byte interrupts = adxl.getInterruptSource(); uncommented
lesept
Have you read the sensor's datasheet ? Pages 12 and after explain the interrupts.
This sensor can detect activity AND inactivity. Maybe this is the source of your problem. The library is quite difficult to understand and to use, and these lines are confusing:
Code: [Select]
Interrupts are triggered both for activity and inactivity ... ?
I think, you should read the datasheet to understand the behavior of the sensor, then read the library source files to select the functions that you really need. Do not try to adapt an example code which seems to be very wide range and maybe not suited to your own needs.
First try to read and print the accel values. Then add the interrupt part then the wake-up from sleep part.
Otherwise, you can try the MPU6050 (see here for example)
uzer123
the pr
Code: [Select]
i have read parts of the datasheet but i wasnt familiar with registers handling...
i had so hard time to make this thing work that i read all the source files library(the one you send) and many others also..
the example code is a code that works in any situation and it was very clear to me how it works (for example the activity and inactivity thing you say)..
FINALLY, i made it work and here is the problem: you have to clear Interrupt source after you call attachInterrupt..AND (i guess its optional but good practice) make ADXL function smaller..
The problem is that i took for granted that sparkfun's example will work perfectly which doesnt and another guy in the comments in sparkfun's page mentioned the same problem.
Anyway to make story short in order for code to work i:
1) added  adxl.getInterruptSource(); after attachInterrupt()
2) comment ADXL_ISR(); in loop, but left a if(trigger){..do something..}
3) ADXL_ISR() just make trigger true
4) the big function with if(adxl.triggered....){ print.... } is called in if(trigger)..
5) adxl.getInterruptSource(); will have to called again at the end of if(trigger)
