Topic: Analog input 0-10V (Read 9062 times) previous topic - next topic
ktalebian
Hi there,
I need to read an analog signal that operates from 0-10V. Arduino Uno only accepts 0-5V. Is there another board that I could use to cover the range? Or is my only option to use two analog inputs?
Thanks
RuggedCircuits
You can just divide your 0V-10V signal down to 0V-5V using a voltage divider:
http://en.wikipedia.org/wiki/Voltage_divider
The Ruggeduino: compatible with Arduino UNO, 24V operation, all I/O's fused and protected
Grumpy_Mike
Quote
That is not an option at all from what I can see. How would you propose to do that?
MarkT
Quote
By being 'creative'?  Subtract 5V with a floating voltage source and then measure the resultant +/-5V differentially between two analog pins (again floating loosely)
retrolefty
Quote
Arduino analog input pins are single ended and ground referenced. Can you provide a drawing showing your 'creative solution?
Lefty
MarkT
Think of a 'bridge tied load' output circuit and then think of it as an input circuit rather than output - you need some trick to hold the mean voltage of the +/-5V signal at 2.5V - basically this relies on the signal being measured being floating w.r.t. Arduino.   And then you need a 5.0V battery to subtract that 5V offset!
retrolefty
That sure sounds like a foxtrot uniform solution.  ;)
MarkT
Compared to two 10k resistors, yes!
Grumpy_Mike
Quote
Seen many 5v batteries then?
