Topic: Flame sensor giving False trigger under sunlight  (Read 147 times) previous topic - next topic
TusharBar
Flame sensor giving false trigger under sun,  what to do
srnet
Put a hat on the sensor to shade it from the sun.
http://www.50dollarsat.info/
http://www.loratracker.uk/
wvmarle
Sun = big ball of FIRE. That are no false triggers you see.
Quality of answers is related to the quality of questions. Good questions will get good answers. Useless answers are a sign of a poor question.
zwieblum
Idahowalker
Use some sort of light detector and use the light detector value as a reference signal that is exceeded.
If you are going to use a hat, do not use a Jimmy hat.
JohnRob
My immediate thought is to create some code that will separate a "flickering" light from a constant light.
However you have provided No information as to what your goal is and how you are currently sensing it (i.e. sensor, processor, schematic etc)
Also you should do a mind experiment:
1) Try to put all you know about your project out of mind.
2) Go back and read your post and think about how others might understand your project with only that one line you posted.
JohnRob
Please do not PM me with thread based messages.  If your thoughts are worth responding,  the group should benefit from your insight.
groundFungus
Thsre is a sticky post named "how to use this forum-please read".  It has some good advice on what makes a good question.  I suggest that you read it.
