Topic: 400 Bad Request after web provider performed server maintenance. (Read 102 times) previous topic - next topic
charlesshoults
I'm working on a project where an Arduino-compatible device (NodeMCU ESP8266) connects to a web server over SSL and retrieves data from a php file.  The data returned is simply a number or series of numbers.  The values are then displayed on a series of 7-segment displays.  Everything was working until around 2am on Thursday, September 19th.  After that time, instead of getting data back from the php script, I'm getting a 400 Bad Request.  I put a couple entries in my php script that should write to error_log and I'm getting nothing on the web server side, so I'm pretty confident I'm not even reaching the file.
I don't know what application versions were in place prior to the updates but I know that these are the current versions:
Apache Version   2.4.39
PHP Version   7.3.8
request:
GET /assets/scripts/php/checkTasks.php?action=getRows&uid=esp8266 HTTP/1.0
Host: battletech-live.net
Connection: close
For HTTP, I've tried 1.0, 1.1 and 2.0 but they don't seem to make a difference.  Prior to the web hosting provider updates, it was working fine with SSL and I was working with setInsecure so that I could retrieve data even with an invalid fingerprint.  Both were working.  The best I can figure is that something needs to change in my request, but I don't know what.
response:
HTTP/1.1 400 Bad Request
Date: Fri, 20 Sep 2019 23:47:41 GMT
Server: Apache
Content-Length: 422
Connection: close
Content-Type: text/html; charset=iso-8859-1
<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<html><head>
<title>400 Bad Request</title>
</head><body>
<h1>Bad Request</h1>
<p>Your browser sent a request that this server could not understand.<br />
</p>
<p>Additionally, a 400 Bad Request
error was encountered while trying to use an ErrorDocument to handle the request.</p>
<hr>
<address>Apache Server at host2011.hostmonster.com Port 443</address>
</body></html>
Bits of code:
WiFiClientSecure client;
  client.setFingerprint(fingerprint);
//  client.setInsecure();
  if (client.connect(host, httpsPort)) {
    String request = String("GET ") + url + " HTTP/1.0 \r\n" + "Host: " + host + "\r\n" + "Connection: close\r\n\r\n";
    client.print(request);
    Serial.print(request);
    while (client.connected()) {
//      String line = client.readStringUntil('\n');
      String line = client.readString();
      Serial.println(line);
  }else{
    Serial.println("connected failed");
Juraj
charlesshoults
This morning, I configured one of my local CentOS boxes for SSL and stripped my sketch down to the most basic components.  I wanted to rule out my hosting provider as being the source of the problem.  As far as an HTTP declaration is concerned, I've tried 1.0, 1.1 and 2.0.
Below is my code, and the serial output of the sketch.
#include <ESP8266WiFi.h>
#include <WiFiClientSecure.h>
const char* ssid = "--------";
const char* password = "--------";
const char* host = "192.168.2.201";
const int httpsPort = 443;
String url = "/battletech-live.fingerprint";
// SHA1 fingerprint of the certificate
 char fingerprint[] PROGMEM = "8F F5 C4 20 BA 96 D3 D7 F6 C8 DA 3B FE 1E F8 4B 77 08 CD 5F";
  WiFi.mode(WIFI_STA);
  WiFi.setOutputPower(10);
  WiFi.begin(ssid, password);
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  Serial.print("IP address: ");
  // Use WiFiClientSecure class to create TLS connection
    Serial.print("connected to ");
    Serial.println(host);
              " HTTP/1.1 \r\n" + "Host: " +
WiFi connected
IP address: 192.168.4.124
connected to 192.168.2.201
Date: Sat, 21 Sep 2019 16:03:58 GMT
Server: Apache/2.4.6 (CentOS) OpenSSL/1.0.2k-fips PHP/5.4.16
Strict-Transport-Security: max-age=63072000; includeSubdomains
X-Frame-Options: DENY
X-Content-Type-Options: nosniff
Content-Length: 226
Connection: close
<html><head>
</head><body>
</p>
</body></html>
The output I get from my hosting provider is a little different.
WiFi connected
connected to battletech-live.net
Date: Sat, 21 Sep 2019 16:09:36 GMT
Server: Apache
Content-Length: 422
Connection: close
<html><head>
</head><body>
</p>
<hr>
</body></html>
Juraj
Danois90
A valid HTTP 1.1 request MUST at least include this:
Code: [Select]
GET /path/document.htm?some=query HTTP/1.1
host: www.thehost.com
EDIT: I see no call to WiFiClientSecure.setCACert() which apparently is mandatory in order to use TLS.
EDIT2: An example.
Instead of mocking what's wrong, teach what's right! ;)
When you get help, remember to thank the helper and give some karma!
Please, do NOT send me any private messages!!
charlesshoults
I'm making some progress.  I rewrote the request and it's now pulling the correct value.
String request = String("GET ") + url + " HTTP/1.1\r\n" +
However, what I'm getting back is more than I want.  All I want is the number at the end, not the header information.
HTTP/1.1 200 OK
Date: Sat, 21 Sep 2019 17:10:40 GMT
Server: Apache
Upgrade: h2,h2c
Connection: Upgrade, close
Content-Length: 1
Content-Type: text/html; charset=UTF-8
2
void getPendingTasks() {
     int ct = line.toInt();
     Serial.println(ct);
Results:
0
0
0
0
0
0
0
0
2
Juraj
charlesshoults
Yes, it looks like the space might have been the main cause.
Danois90
If you only want the value of the last line, then should be able to do this:
Code: [Select]
String line;
while (client.connected()) line = client.readStringUntil('\n');
int value = line.toInt();
Serial.print("Value is: ");
Serial.println(value);
charlesshoults
Thank you for all the help.  Danois90, your solution is really close to what I came up with too.  I didn't put it all on one line, but it works.
From there, I'm able to send the value to a writeDigit function to display the value on 7-segment displays.
