Topic: Sim Racing 32 Button having Error  (Read 41 times) previous topic - next topic
sweeseng85
HI all ,
I very new on Arduino , recently playing sim racing and saw button make the sim button . so decide to make for my own  . get all the part install and setup . sadly I was sticked at Arduino this part
after I Sketch copy from youtube which is
#include <Esplora.h>
//BUTTON BOX
//USE w ProMicro
//Tested in WIN10 + Assetto Corsa
//AMSTUDIO
//20.8.17
#include <Keypad.h>
#include <Joystick.h>
#define ENABLE_PULLUPS
#define NUMROTARIES 4
#define NUMBUTTONS 24
#define NUMROWS 5
#define NUMCOLS 5
byte buttons[NUMROWS][NUMCOLS] = {
  {0,1,2,3,4},
  {5,6,7,8,9},
  {10,11,12,13,14},
  {15,16,17,18,19},
  {20,21,22,23},
struct rotariesdef {
  byte pin1;
  byte pin2;
  int ccwchar;
  int cwchar;
  volatile unsigned char state;
rotariesdef rotaries[NUMROTARIES] {
  {0,1,24,25,0},
  {2,3,26,27,0},
  {4,5,28,29,0},
  {6,7,30,31,0},
#define DIR_CCW 0x10
#define DIR_CW 0x20
#define R_START 0x0
#ifdef HALF_STEP
#define R_CCW_BEGIN 0x1
#define R_CW_BEGIN 0x2
#define R_START_M 0x3
#define R_CW_BEGIN_M 0x4
#define R_CCW_BEGIN_M 0x5
const unsigned char ttable[6][4] = {
  // R_START (00)
  {R_START_M,            R_CW_BEGIN,     R_CCW_BEGIN,  R_START},
  // R_CCW_BEGIN
  {R_START_M | DIR_CCW, R_START,        R_CCW_BEGIN,  R_START},
  // R_CW_BEGIN
  {R_START_M | DIR_CW,  R_CW_BEGIN,     R_START,      R_START},
  // R_START_M (11)
  {R_START_M,            R_CCW_BEGIN_M,  R_CW_BEGIN_M, R_START},
  // R_CW_BEGIN_M
  {R_START_M,            R_START_M,      R_CW_BEGIN_M, R_START | DIR_CW},
  // R_CCW_BEGIN_M
  {R_START_M,            R_CCW_BEGIN_M,  R_START_M,    R_START | DIR_CCW},
#else
#define R_CW_FINAL 0x1
#define R_CW_NEXT 0x3
#define R_CCW_BEGIN 0x4
#define R_CCW_FINAL 0x5
#define R_CCW_NEXT 0x6
const unsigned char ttable[7][4] = {
  // R_START
  {R_START,    R_CW_BEGIN,  R_CCW_BEGIN, R_START},
  // R_CW_FINAL
  {R_CW_NEXT,  R_START,     R_CW_FINAL,  R_START | DIR_CW},
  // R_CW_BEGIN
  {R_CW_NEXT,  R_CW_BEGIN,  R_START,     R_START},
  // R_CW_NEXT
  {R_CW_NEXT,  R_CW_BEGIN,  R_CW_FINAL,  R_START},
  // R_CCW_BEGIN
  {R_CCW_NEXT, R_START,     R_CCW_BEGIN, R_START},
  // R_CCW_FINAL
  {R_CCW_NEXT, R_CCW_FINAL, R_START,     R_START | DIR_CCW},
  // R_CCW_NEXT
  {R_CCW_NEXT, R_CCW_FINAL, R_CCW_BEGIN, R_START},
#endif
byte rowPins[NUMROWS] = {21,20,19,18,15};
byte colPins[NUMCOLS] = {14,16,10,9,8};
Keypad buttbx = Keypad( makeKeymap(buttons), rowPins, colPins, NUMROWS, NUMCOLS);
Joystick_ Joystick(JOYSTICK_DEFAULT_REPORT_ID,
  JOYSTICK_TYPE_JOYSTICK, 32, 0,
  false, false, false, false, false, false,
  false, false, false, false, false);
  Joystick.begin();
  rotary_init();}
  CheckAllEncoders();
  CheckAllButtons();
void CheckAllButtons(void) {
      if (buttbx.getKeys())
       for (int i=0; i<LIST_MAX; i++)
           if ( buttbx.key.stateChanged )
            switch (buttbx.key.kstate) {
                    case PRESSED:
                    case HOLD:
                              Joystick.setButton(buttbx.key.kchar, 1);
                    case RELEASED:
                    case IDLE:
                              Joystick.setButton(buttbx.key.kchar, 0);
void rotary_init() {
  for (int i=0;i<NUMROTARIES;i++) {
    pinMode(rotaries.pin1, INPUT);
    pinMode(rotaries.pin2, INPUT);
    #ifdef ENABLE_PULLUPS
      digitalWrite(rotaries.pin1, HIGH);
      digitalWrite(rotaries.pin2, HIGH);
    #endif
unsigned char rotary_process(int _i) {
   unsigned char pinstate = (digitalRead(rotaries[_i].pin2) << 1) | digitalRead(rotaries[_i].pin1);
  rotaries[_i].state = ttable[rotaries[_i].state & 0xf][pinstate];
  return (rotaries[_i].state & 0x30);
void CheckAllEncoders(void) {
    unsigned char result = rotary_process(i);
    if (result == DIR_CCW) {
      Joystick.setButton(rotaries.ccwchar, 1); delay(50); Joystick.setButton(rotaries.ccwchar, 0);
    if (result == DIR_CW) {
      Joystick.setButton(rotaries.cwchar, 1); delay(50); Joystick.setButton(rotaries.cwchar, 0);
however , when I verify have some error , I already install the keypad and joystick from library . some how still got error for joystick portion .
can anyone guide and help me on this .
my error show below
Arduino: 1.8.9 (Windows 10), Board: "Arduino/Genuino Uno"
In file included from C:\Users\AST009000\Documents\Arduino\libraries\Keypad\src/Keypad.h:36:0,
                 from D:\Downloads\32-FUNCTION-BUTTON-BOX-master\32-FUNCTION-BUTTON-BOX-master\ARDUINO_BUTTON_BOXV2\ARDUINO_BUTTON_BOXV2.ino:9:
C:\Users\AST009000\Documents\Arduino\libraries\Keypad\src/Key.h:41:21: error: 'PRESSED' redeclared as different kind of symbol
 typedef enum{ IDLE, PRESSED, HOLD, RELEASED } KeyState;
In file included from D:\Downloads\32-FUNCTION-BUTTON-BOX-master\32-FUNCTION-BUTTON-BOX-master\ARDUINO_BUTTON_BOXV2\ARDUINO_BUTTON_BOXV2.ino:1:0:
C:\Program Files (x86)\Arduino\libraries\Esplora\src/Esplora.h:73:15: note: previous declaration 'const boolean PRESSED'
 const boolean PRESSED   = LOW;
C:\Users\AST009000\Documents\Arduino\libraries\Keypad\src/Key.h:41:36: error: 'RELEASED' redeclared as different kind of symbol
C:\Program Files (x86)\Arduino\libraries\Esplora\src/Esplora.h:74:15: note: previous declaration 'const boolean RELEASED'
 const boolean RELEASED  = HIGH;
ARDUINO_BUTTON_BOXV2:97:1: error: 'Joystick_' does not name a type
D:\Downloads\32-FUNCTION-BUTTON-BOX-master\32-FUNCTION-BUTTON-BOX-master\ARDUINO_BUTTON_BOXV2\ARDUINO_BUTTON_BOXV2.ino: In function 'void setup()':
ARDUINO_BUTTON_BOXV2:103:11: error: expected unqualified-id before '.' token
   Joystick.begin();
D:\Downloads\32-FUNCTION-BUTTON-BOX-master\32-FUNCTION-BUTTON-BOX-master\ARDUINO_BUTTON_BOXV2\ARDUINO_BUTTON_BOXV2.ino: In function 'void CheckAllButtons()':
ARDUINO_BUTTON_BOXV2:124:39: error: expected unqualified-id before '.' token
ARDUINO_BUTTON_BOXV2:127:21: error: duplicate case value
                     case IDLE:
ARDUINO_BUTTON_BOXV2:122:21: error: previously used here
                     case PRESSED:
ARDUINO_BUTTON_BOXV2:128:39: error: expected unqualified-id before '.' token
D:\Downloads\32-FUNCTION-BUTTON-BOX-master\32-FUNCTION-BUTTON-BOX-master\ARDUINO_BUTTON_BOXV2\ARDUINO_BUTTON_BOXV2.ino: In function 'void CheckAllEncoders()':
ARDUINO_BUTTON_BOXV2:159:15: error: expected unqualified-id before '.' token
ARDUINO_BUTTON_BOXV2:159:70: error: expected unqualified-id before '.' token
ARDUINO_BUTTON_BOXV2:162:15: error: expected unqualified-id before '.' token
ARDUINO_BUTTON_BOXV2:162:69: error: expected unqualified-id before '.' token
exit status 1
option enabled in File -> Preferences.
