Here is some code that I use to access SPI on the ESP32
The ESP32_SPI_API.h tab
#include <driver/spi_master.h>
#include "sdkconfig.h"
#include "esp_system.h" //This inclusion configures the peripherals in the ESP system.
uint8_t GetLowBits();
int8_t GetHighBits();
int fReadSPIdata16bits( spi_device_handle_t &h, int address );
int fWriteSPIdata8bits( spi_device_handle_t &h, int address, int sendData );
int fInitializeSPI_Devices( spi_device_handle_t &h, int csPin);
int fInitializeSPI_Channel( int spiCLK, int spiMOSI, int spiMISO, spi_host_device_t SPI_Host, bool EnableDMA);
The cpp tab
#include "ESP32_SPI_API.h"
uint8_t txData[2] = { };
int8_t rxData[25] = { };
uint8_t low;
int8_t high;
return low;
return high;
esp_err_t intError;
spi_bus_config_t bus_config = { };
bus_config.sclk_io_num = spiCLK; // CLK
bus_config.mosi_io_num = spiMOSI; // MOSI
bus_config.miso_io_num = spiMISO; // MISO
bus_config.quadwp_io_num = -1; // Not used
bus_config.quadhd_io_num = -1; // Not used
intError = spi_bus_initialize( HSPI_HOST, &bus_config, EnableDMA) ;
return intError;
esp_err_t intError;
spi_device_interface_config_t dev_config = { }; // initializes all field to 0
dev_config.address_bits = 0;
dev_config.command_bits = 0;
dev_config.dummy_bits = 0;
dev_config.mode = 3;
dev_config.duty_cycle_pos = 0;
dev_config.cs_ena_posttrans = 0;
dev_config.cs_ena_pretrans = 0;
dev_config.clock_speed_hz = 7000000;
dev_config.spics_io_num = csPin;
dev_config.flags = 0;
dev_config.queue_size = 1;
dev_config.pre_cb = NULL;
dev_config.post_cb = NULL;
spi_bus_add_device(HSPI_HOST, &dev_config, &h);
} // void fInitializeSPI_Devices()
int fReadSPIdata16bits( spi_device_handle_t &h, int _address )
uint8_t address = _address;
esp_err_t intError = 0;
low=0; high=0;
spi_transaction_t trans_desc;
trans_desc = { };
trans_desc.addr = 0;
trans_desc.cmd = 0;
trans_desc.flags = 0;
trans_desc.length = (8 * 3); // total data bits
trans_desc.tx_buffer = txData;
trans_desc.rxlength = 8 * 2 ; // Number of bits NOT number of bytes
trans_desc.rx_buffer = rxData;
txData[0] = address | 0x80;
intError = spi_device_transmit( h, &trans_desc);
low = rxData[0]; high = rxData[1];
return intError;
} // void fSendSPI( uint8_t count, uint8_t address, uint8_t DataToSend)
int fWriteSPIdata8bits( spi_device_handle_t &h, int _address, int _sendData )
int8_t sendData = _sendData;
esp_err_t intError;
trans_desc = { };
trans_desc.cmd = 0;
trans_desc.length = (8 * 2); // total data bits
trans_desc.rxlength = 0 ; // Number of bits NOT number of bytes
trans_desc.rx_buffer = NULL;
txData[0] = address & 0x7F;
txData[1] = sendData;
return intError;
} // void fWriteSPIdata8bits( spi_device_handle_t &h, uint8_t address, uint8_t sendData )
