Topic: Read an SMS, identify the sender phone number, and answer to the sender (Read 9504 times) previous topic - next topic
ilteo85
Hi, i'm using arduino and SIM808 V3.2 for a project.
I ve already write the sketch for chek recived SMS and if it is a word that i choose ("STATO")
send an SMS.
I would like that the answer will be send not to a pre established number.
I wish to read the senders number and answer him.
Is it possible? How?
Here is my code right now
Code: [Select]
#include <SoftwareSerial.h>
// Configure software serial port
SoftwareSerial mySerial(10, 11);
// Variable to store text message
String textMessage;
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  Serial.println("Serial begin ok");
  // set the data rate for the SoftwareSerial port
  mySerial.begin(9600);
  mySerial.println("AT");
void loop(){
  ricezione();
  delay(2000);
void ricezione(){
  Serial.println ("controllo ricezione SMS");
  // AT command to set mySerial to SMS mode
  mySerial.print("AT+CMGF=1\r");
  delay(100);
  // Read the first SMS saved in the sim
  mySerial.print("AT+CMGR=1\r");
  delay(10);
  if(mySerial.available()>0){
    textMessage = mySerial.readString();
    Serial.print(textMessage);
    delay(10);
  // check if the SMS is "STATO"
  if(textMessage.indexOf("STATO")>=0){
    Serial.println("Invio info stato arnia");
    smsstato();
    textMessage = "";
void smsstato(){
  // delete the first SMS
  mySerial.print("AT+CMGD=1\r");
  delay(100);
  /i wish that phone number change with the phone number of the sender of SMS
  mySerial.print("AT+CMGS=\"+39348395xxxx\"\r");
  //The text of the message to be sent.
  mySerial.print("prova invio sms: ");
  mySerial.write(0x1A);
Thank you very much!
kiliannam
Hi ileto85,
I am having a similar problem withmy project. Were you able to soleve the problem? and if so, would you mind posting  it here?
Thank you :)
ilteo85
Hi! Yes i've solved it! Here is the two function i've used :
Code: [Select]
String CellNumtemp;
String CellNum;
// check if there are incoming SMS
void ricezione(){
  delay(100);
  delay(10);
    delay(10);
    //save the phone number of the senders in a string (this works with italian region you must adapt to   yours)
    CellNumtemp = textMessage.substring(textMessage.indexOf("+39"));
    CellNum = CellNumtemp.substring(0,13);
    smsstato();
    CellNumtemp = "";
    textMessage = "";
  delay(100);
  mySerial.print("AT+CMGD=2\r");
  delay(100);
// Send sms with all the information to the number stored
void smsstato(){
  delay(100);
  mySerial.print("AT+CMGS=\"");
  mySerial.print(CellNum);
  mySerial.print("\"\r");
  mySerial.print("INFO: Latitudine: ");
  mySerial.print(latitude);
  mySerial.print(", Longitudine: ");
  mySerial.print(logitude);
  mySerial.print(", Ampere: ");
  mySerial.print(consumotemp);
  Serial.println("sms stato");
I extract the number using 2 string.. that's the only way i was able to solve it.. I think that
there are more efficient ways..
Let me know if you found it useful and if it's all clear
Absolute_Advance_Automation
Code: [Select]
String CellNumtemp;
String CellNum;
void ricezione(){
  delay(100);
  delay(10);
    delay(10);
    smsstato();
    CellNumtemp = "";
    textMessage = "";
  delay(100);
  delay(100);
void smsstato(){
  delay(100);
yeah it's working. thanks
kiliannam
Thank you for the quick response, it worked for me too, Thanks :)
