Topic: Read an SMS, identify the sender phone number, and answer to the sender (Read 15614 times) previous topic - next topic
ilteo85
Hi, i'm using arduino and SIM808 V3.2 for a project.
I ve already write the sketch for chek recived SMS and if it is a word that i choose ("STATO")
send an SMS.
I would like that the answer will be send not to a pre established number.
I wish to read the senders number and answer him.
Is it possible? How?
Here is my code right now
#include <SoftwareSerial.h>
// Configure software serial port
SoftwareSerial mySerial(10, 11);
// Variable to store text message
String textMessage;
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  Serial.println("Serial begin ok");
  // set the data rate for the SoftwareSerial port
  mySerial.begin(9600);
  mySerial.println("AT");
void loop(){
  ricezione();
  delay(2000);
void ricezione(){
  Serial.println ("controllo ricezione SMS");
  // AT command to set mySerial to SMS mode
  mySerial.print("AT+CMGF=1\r");
  delay(100);
  // Read the first SMS saved in the sim
  mySerial.print("AT+CMGR=1\r");
  delay(10);
  if(mySerial.available()>0){
    textMessage = mySerial.readString();
    Serial.print(textMessage);
    delay(10);
  // check if the SMS is "STATO"
  if(textMessage.indexOf("STATO")>=0){
    Serial.println("Invio info stato arnia");
    smsstato();
    textMessage = "";
void smsstato(){
  // delete the first SMS
  mySerial.print("AT+CMGD=1\r");
  delay(100);
  /i wish that phone number change with the phone number of the sender of SMS
  mySerial.print("AT+CMGS=\"+39348395xxxx\"\r");
  //The text of the message to be sent.
  mySerial.print("prova invio sms: ");
  mySerial.write(0x1A);
Thank you very much!
kiliannam
Hi ileto85,
I am having a similar problem withmy project. Were you able to soleve the problem? and if so, would you mind posting  it here?
Thank you :)
ilteo85
Hi! Yes i've solved it! Here is the two function i've used :
String CellNumtemp;
String CellNum;
// check if there are incoming SMS
void ricezione(){
  delay(100);
  delay(10);
    delay(10);
    //save the phone number of the senders in a string (this works with italian region you must adapt to   yours)
    CellNumtemp = textMessage.substring(textMessage.indexOf("+39"));
    CellNum = CellNumtemp.substring(0,13);
    smsstato();
    CellNumtemp = "";
    textMessage = "";
  delay(100);
  mySerial.print("AT+CMGD=2\r");
  delay(100);
// Send sms with all the information to the number stored
void smsstato(){
  delay(100);
  mySerial.print("AT+CMGS=\"");
  mySerial.print(CellNum);
  mySerial.print("\"\r");
  mySerial.print("INFO: Latitudine: ");
  mySerial.print(latitude);
  mySerial.print(", Longitudine: ");
  mySerial.print(logitude);
  mySerial.print(", Ampere: ");
  mySerial.print(consumotemp);
  Serial.println("sms stato");
I extract the number using 2 string.. that's the only way i was able to solve it.. I think that
there are more efficient ways..
Let me know if you found it useful and if it's all clear
Absolute_Advance_Automation
String CellNumtemp;
String CellNum;
void ricezione(){
  delay(100);
  delay(10);
    delay(10);
    smsstato();
    CellNumtemp = "";
    textMessage = "";
  delay(100);
  delay(100);
void smsstato(){
  delay(100);
yeah it's working. thanks
kiliannam
Thank you for the quick response, it worked for me too, Thanks :)
rwp908
Thanks to all on this posting.
Output At Serial Monitor or Putty
08:50:37.247 -> Turn ON SIM7000......
08:50:44.535 -> Turn ON !
08:50:44.535 -> Set baud rate......
08:50:49.551 -> Set baud rate:19200
08:50:49.551 -> For example, if you type AT\r\n, OK\r\n will be responsed!
08:50:49.551 -> Enter your AT command :
08:50:54.625 -> SMS Sent
08:50:55.608 -> AT+CMGF=1
08:50:55.608 -> OK
08:50:55.608 -> AT+CMGS="5552341212"
08:50:55.608 -> > INFO: Latitudine: , Lo
08:50:57.132 -> +CMGS: 22
08:50:57.132 ->
08:50:57.132 -> OK
  * File  : DFRobot_SIM7000_ATtest.ino
  * Power : SIM7000 needs 7-12V DC power supply
  * Brief : This example use the serial port to send AT command to control the SIM7000
  * With initialization completed, we can enter AT command to SIM7000 directly
  * Note  : If you use Mega please connect PIN8 PIN10 and set PIN_RX = 10
  * The AT command must end with CR&LF
#include <DFRobot_SIM7000.h>
#define PIN_TX     7
#define PIN_RX     8
SoftwareSerial     mySerial(PIN_RX,PIN_TX);
DFRobot_SIM7000    sim7000;
int count=0;
String CellNum="5552341212";
String CellNumtemp;
    sim7000.begin(mySerial);
    sim7000.turnOFF();
    delay(5000);
    Serial.println("Turn ON SIM7000......");
    if(sim7000.turnON()){                             //Turn ON SIM7000
        Serial.println("Turn ON !");
    Serial.println("Set baud rate......");
    if(sim7000.setBaudRate(19200)){                   //Set baud rate from 115200 to 19200
        Serial.println("Set baud rate:19200");
        // Serial.println("AT+CMGF=1");
        // Serial.println("DQ = Double Quotes");
        // Serial.println("AT+CMGS=DQ5552341212DQ");
        // Serial.println("From Rob Parenton SIM7000E Test Chip on Arduino Board! then Ctrl-Z");
    }else{
        Serial.println("Faile to set baud rate");
        while(1);
    mySerial.begin(19200);
    Serial.println("For example, if you type AT\\r\\n, OK\\r\\n will be responsed!");
    Serial.println("Enter your AT command :");
    count=1;
    // Serial.println(count);
       if(count==1){
       mySerial.print("AT+CMGF=1\r");  // set SMS mode to text
       mySerial.listen();
       while(mySerial.available()){
       Serial.write(mySerial.read());
        mySerial.flush();
        while(Serial.available()){
            mySerial.write(Serial.read());
    delay(30);
     if(count==1){
     if(count==1){
       // mySerial.print(latitude);
       // mySerial.print(logitude);
       // mySerial.print(consumotemp);
        Serial.println("SMS Sent");
     count++;
