Topic: Error in upload (Read 169 times) previous topic - next topic
mandrakex
Hi! I am trying to use a bluetooth module and this following error apears
Arduino: 1.8.10 (Windows 7), Board: "Arduino/Genuino Uno"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\User\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0X2341_0X0043 -ide-version=10810 -build-path C:\Users\User\AppData\Local\Temp\arduino_build_303861 -warnings=none -build-cache C:\Users\User\AppData\Local\Temp\arduino_cache_500446 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino5.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\User\Documents\Arduino\potenciometro2\potenciometro2.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\User\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0X2341_0X0043 -ide-version=10810 -build-path C:\Users\User\AppData\Local\Temp\arduino_build_303861 -warnings=none -build-cache C:\Users\User\AppData\Local\Temp\arduino_cache_500446 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino5.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\User\Documents\Arduino\potenciometro2\potenciometro2.ino
Using board 'uno' from platform in folder: C:\Program
Using core 'arduino' from platform in folder: C:\Program
Detecting libraries used...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10810 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_303861\\sketch\\potenciometro2.ino.cpp" -o nul
Alternatives for SoftwareSerial.h: [SoftwareSerial@1.0 espsoftwareserial-master@1.0]
ResolveLibrary(SoftwareSerial.h)
  -> candidates: [SoftwareSerial@1.0 espsoftwareserial-master@1.0]
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10810 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SoftwareSerial\\src" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_303861\\sketch\\potenciometro2.ino.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10810 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SoftwareSerial\\src" "C:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SoftwareSerial\\src\\SoftwareSerial.cpp" -o nul
Generating function prototypes...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10810 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SoftwareSerial\\src" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_303861\\sketch\\potenciometro2.ino.cpp" -o "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_303861\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_303861\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10810 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\SoftwareSerial\\src" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_303861\\sketch\\potenciometro2.ino.cpp" -o "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_303861\\sketch\\potenciometro2.ino.cpp.o"
Compiling libraries...
Compiling library "SoftwareSerial"
Using previously compiled file: C:\Users\User\AppData\Local\Temp\arduino_build_303861\libraries\SoftwareSerial\SoftwareSerial.cpp.o
Compiling core...
Using precompiled core: C:\Users\User\AppData\Local\Temp\arduino_cache_500446\core\core_arduino_avr_uno_0c812875ac70eb4a9b385d8fb077f54c.a
Linking everything together...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_303861/potenciometro2.ino.elf" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_303861\\sketch\\potenciometro2.ino.cpp.o" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_303861\\libraries\\SoftwareSerial\\SoftwareSerial.cpp.o" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_303861/..\\arduino_cache_500446\\core\\core_arduino_avr_uno_0c812875ac70eb4a9b385d8fb077f54c.a" "-LC:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_303861" -lm
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_303861/potenciometro2.ino.elf" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_303861/potenciometro2.ino.eep"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-objcopy" -O ihex -R .eeprom "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_303861/potenciometro2.ino.elf" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_303861/potenciometro2.ino.hex"
Multiple libraries were found for "SoftwareSerial.h"
 Used: C:\Program
 Not used: C:\Program
Using library SoftwareSerial at version 1.0 in folder: C:\Program Files
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-size" -A "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_303861/potenciometro2.ino.elf"
The full error message dont fit here
pert
Do you have the Bluetooth module connected to pins 0 and 1 of your Arduino board?
sterretje
#2
Sep 23, 2019, 05:45 am Last Edit: Sep 23, 2019, 05:45 am by sterretje
If the full error message is too big, you can save it to a text file and attach it to a post.
If it's an upload error (and not a compile error), you can reduce the size by disabling the "show verbose output during compilation" in file -> preferences.
If you understand an example, use it.
If you don't understand an example, don't use it.
Electronics engineer by trade, software engineer by profession. Trying to get back into electronics after 15 years absence.
mandrakex
#3
Sep 24, 2019, 12:12 am Last Edit: Sep 24, 2019, 12:17 am by mandrakex
Yes, they are connected.
I'll try this later. Thank you
sterretje
During upload, you can not have things connected to the serial pons (0 and 1)'
