Topic: Status of on board blinking LED (Read 354 times) previous topic - next topic
adusumir
Hey guys,
Relatively new to arduino programming, hoping to find some help here about my code:
So I'm trying to blink the on-board led of a arduino uno and at the same time plot it's status on a graph as 1s and 0s. The following is my code:
int ledPin = 13;
  pinMode(ledPin, OUTPUT);
  digitalWrite(ledPin, HIGH);
  delay(100);
  digitalWrite(ledPin, LOW);
  delay(100);
  int a = digitalRead(ledPin);
  Serial.println(a);
However, when I run this, the serial monitor only displays a 0 when ever the led turns on instead of series of 1s and 0s. As a result the graph is just a line on the x axis as shown on the attached picture.
What changes should I do so that I get a proper 1-0 step graph vs time?
Thanks in advance.
slipstick
You read the LED status just after you've set it LOW. So of course it's always LOW.
If you want to see both states put a serial print() or println() HIGH or LOW immediately after EACH digitalWrite() HIGH or LOW.
Steve
septillion
#2
Sep 25, 2019, 03:47 pm Last Edit: Sep 25, 2019, 03:47 pm by septillion
All the stuff isn't happening in parallel, execution is just top down :)
So like slipstick said (but with a twist):
Code: [Select]
const byte LedPin = 13;
void setup(){
  pinMode(LedPin, OUTPUT);
void loop(){
  digitalToggle(ledPin);
  bool pinState = digitalRead(LedPin);
  Serial.println(pinState);
  delay(100);
void digitalToggle(byte pin){
  digitalWrite(pin, !digitalRead(pin));
BUT, this still uses delay so will kind of give you the same trouble if you try to add anything to the program. For that, use millis() like in "Blink without delay":
Code: [Select]
unsigned long blinkMillis;
void setup(){
  const unsigned long CurrentMillis = millis();
  if(CurrentMillis - blinkMillis >= 100){
    blinkMillis = CurrentMillis;
Use fricking code tags!!!!
I want x => I would like x, I need help => I would like help, Need fast => Go and pay someone to do the job...
NEW Library to make fading leds a piece of cake
https://github.com/septillion-git/FadeLed
