Topic: u center - no fix (Read 929 times) previous topic - next topic
ilan7
-Google Translate-
Hello everyone :))
I'm used m8n.
When I upload the code to arduino and open the serial monitor to 115200
Everything works well.
But when I open the u center ( baudrate to 115200 ) Nothing works, no fix.
And I don't get any data from u center.
( The reason I need u center is to change the rate to 5hz, gps and glonass )
I would love to get help
many thanks :))
Code: [Select]
#include <NeoSWSerial.h>
#include <NMEAGPS.h>
#define GPSBaud 9600
#define ConsoleBaud 115200
// The serial connection to the GPS device
//AltSoftSerial gpsPort; // pins 8 & 9 would be better!
#define RXPin 8
#define TXPin 7
NeoSWSerial gpsPort(RXPin, TXPin);
NMEAGPS gps;
uint8_t updates = 0; // used to count elapsed seconds
NeoGPS::Location_t des( 44.88285, -68.67253 ); // Orono, ME
  Serial.begin(ConsoleBaud);
  gpsPort.begin(GPSBaud);
  // Process characters from the GPS
  while (gps.available( gpsPort )) {
    gps_fix fix = gps.read();
    // Every 5 seconds, do an update.
    if (++updates >= 5) {
      updates = 0;
      // If we have a location, give instructions
      if (fix.valid.location) {
        // Establish our current status
        double distanceToDestination = fix.location.DistanceKm( des );
        double courseToDestination   = fix.location.BearingToDegrees( des );
        const __FlashStringHelper *directionToDestination =
                                        compassDir(courseToDestination);
        int courseChangeNeeded = (int)(360 + courseToDestination - fix.heading()) % 360;
        // debug
        Serial.print( F("DEBUG: Course2Dest: ") );
        Serial.print(courseToDestination);
        Serial.print( F("  CurCourse: ") );
        if (fix.valid.heading)
          Serial.print( fix.heading() );
        Serial.print( F("  Dir2Dest: ") );
        Serial.print(directionToDestination);
        Serial.print( F("  RelCourse: ") );
        Serial.print(courseChangeNeeded);
        Serial.print( F("Lat: ") );
        Serial.print( fix.latitude(), 6 );
        Serial.print( F("  Lon: ") );
        Serial.println( fix.longitude(), 6 );
        Serial.print( F("  CurSpd: ") );
        if (fix.valid.speed)
          Serial.print( fix.speed_kph() );
        Serial.println('\n');
        // ???  THIS ISN'T A THING
        //Serial.print( F("current Angle: ") );
        //Serial.println(atan2(gps.location.lat(), gps.location.lng())*180/M_PI);
        // Within 20 meters of destination?  We're here!
        if (distanceToDestination <= 20.0)
          Serial.println( F("CONGRATULATIONS: You've arrived!") );
          exit(1);
        Serial.print( F("DISTANCE: ") );
        Serial.print(distanceToDestination);
        Serial.println( F(" meters to go.") );
        Serial.print( F("INSTRUCTION: ") );
        // Standing still? Just indicate which direction to go.
        if (fix.speed_kph() < 5.0)
          Serial.print( F("Head ") );
          Serial.println( '.' );
        } else // suggest a course change
        if ((courseChangeNeeded >= 345) || (courseChangeNeeded < 15))
          Serial.println( F("Keep on straight ahead!") );
        else if ((courseChangeNeeded >= 315) && (courseChangeNeeded < 345))
          Serial.println( F("Veer slightly to the left.") );
        else if ((courseChangeNeeded >= 15) && (courseChangeNeeded < 45))
          Serial.println( F("Veer slightly to the right.") );
        else if ((courseChangeNeeded >= 255) && (courseChangeNeeded < 315))
          Serial.println( F("Turn to the left.") );
        else if ((courseChangeNeeded >= 45) && (courseChangeNeeded < 105))
          Serial.println( F("Turn to the right.") );
          Serial.println( F("Turn completely around.") );
        Serial.println( F("Waiting for GPS fix...") );
//  This snippet is from NMEAaverage.  It keeps all the
//    compass direction strings in FLASH memory, saving RAM.
const char nCD  [] PROGMEM = "N";
const char nneCD[] PROGMEM = "NNE";
const char neCD [] PROGMEM = "NE";
const char eneCD[] PROGMEM = "ENE";
const char eCD  [] PROGMEM = "E";
const char eseCD[] PROGMEM = "ESE";
const char seCD [] PROGMEM = "SE";
const char sseCD[] PROGMEM = "SSE";
const char sCD  [] PROGMEM = "S";
const char sswCD[] PROGMEM = "SSW";
const char swCD [] PROGMEM = "SW";
const char wswCD[] PROGMEM = "WSW";
const char wCD  [] PROGMEM = "W";
const char wnwCD[] PROGMEM = "WNW";
const char nwCD [] PROGMEM = "NW";
const char nnwCD[] PROGMEM = "NNW";
const char * const dirStrings[] PROGMEM =
  { nCD, nneCD, neCD, eneCD, eCD, eseCD, seCD, sseCD,
    sCD, sswCD, swCD, wswCD, wCD, wnwCD, nwCD, nnwCD };
const __FlashStringHelper *compassDir( uint16_t bearing ) // degrees CW from N
  const int16_t directions    = sizeof(dirStrings)/sizeof(dirStrings[0]);
  const int16_t degreesPerDir = 360 / directions;
        int8_t  dir           = (bearing + degreesPerDir/2) / degreesPerDir;
  while (dir < 0)
    dir += directions;
  while (dir >= directions)
    dir -= directions;
  return (const __FlashStringHelper *) pgm_read_ptr( &dirStrings[ dir ] );
} // compassDir
