Topic: Adjusting servo speed (Read 39351 times) previous topic - next topic
unb
Hi!
i'm almost done with my little project  8-)
The only thing i need to figure out now, is that how i adjust the speed of a servo.
Help me with the following code:  ::)
Code: [Select]
int ledPin = 13;
int inputPin1 = 2;
int inputPin2 = 4;
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
               // a maximum of eight servo objects can be created
int pos = 0;    // variable to store the servo position
 // initialize the LED pin as an output:
 pinMode(ledPin, OUTPUT);
 // initialize the pushbutton pin as an input:
 pinMode(inputPin1, INPUT);
 pinMode(inputPin2, INPUT);
 myservo.attach(9);  // attaches the servo on pin 9 to the servo object
void loop(){
 if (digitalRead(inputPin1) == LOW) {
     for(pos = 20; pos < 100; pos += 1)  // goes from 0 degrees to 180 degrees
                                   // in steps of 1 degree
   myservo.write(pos);              // tell servo to go to position in variable 'pos'
   delay(30);
 }else if  (digitalRead(inputPin2) == LOW){
    for(pos = 100; pos>=20; pos-=1)     // goes from 180 degrees to 0 degrees
   delay(30);
newman
well just increase the delay until you find it slow enough but it can sometimes be jittery
unb
That didnt seemed to work.
Any suggestions?
GrooveFlotilla
What exactly didn't 'seem to work'?
Decide how fast you want to turn, say 180 degrees in 5 seconds, then divide 5 by 180 to get the delay per degree step.
Don't forget to work in milliseconds.
Some people are like Slinkies.
Not really good for anything, but they bring a smile to your face when pushed down the stairs.
newman
have a look at this
http://arduino.cc/en/Tutorial/Sweep
PaulS
Code: [Select]
   delay(30);
Without braces, the only command execute in the body of the for loop is the myservo.write() command. Since that is a non-blocking function, the for loop completes very quickly.
You want curly braces around the myservo.write() and delay() calls, so that the servo moves a little, and waits, then move some more, and waits, until it has moved enough.
jezuz
Just to add, you can also change the number of steps per time frame the servo makes, so in your for loop, change pos += 1 to pos += 5 or something. Of course, there's a limit to this, which is the max speed of the servo.
