Topic: Quick question from a beginner (Read 629 times) previous topic - next topic
TigerTran
Hi alll, Im new to the world programming. Do you guys have any tips for beginner?
Robin2
Two or three hours spent thinking and reading documentation solves most programming problems.
pert
Start with the tutorials here:
https://www.arduino.cc/en/Tutorial/BuiltInExamples
Read through the code line by line and make sure you fully understand what each line of code does. You can use the Arduino Language Reference to help when there are things you don't understand:
https://www.arduino.cc/reference/en
If you don't find the information you need there, research on Google until you find it.
Once you think you understand an example and have successfully ran the unmodified example on your Arduino, make a change to the code, upload it, then verify that the change had the expected effect.
As you get further down in the tutorials, you may find that some of them are not applicable to the areas you want to learn about. It's OK to skip over those. However, you definitely need to work your way through most of the more basic tutorial because they will teach you concepts that are essential to any project.
We're happy to help you in your learning process here on the forum, but we do have some guidelines we expect you to follow. Make sure to carefully read the "How to use this forum - please read." post.
Lewis-H
#1: Always Stick to One Task at a Time.
#2: Different People Find Different Things Easy.
#3: Your Work Can Be Only 80% Complete.
#4: Learn How to Google.
#5: Don't Be Afraid to Ask for Help or to Help People Back.
#6: Technology Always Changes.
#7: It's Okay Not to Contribute to Open Source.
#8: Programmers Fail All the Time.
Hope these tips helps you!
Regards,
Lewis
