Topic: speed control question. (Read 80 times) previous topic - next topic
dthammer181
Hello.  Complete newbie to Arduino.  I am working a project and trying to learn all I can.  I was able to come up with this simple sketch from putting together pieces from sketches I found online,  There will be a lot more when I'm done for sure.  For now I'd like to add some some different speeds to this sketch.  How do I go about doing that?  I have pasted the sketch below. Thank you.
const int dirPin = 2;  // Direction
const int stepPin = 3; // Step
// Motor steps per rotation
const int STEPS_PER_REV = 200;
  // Setup the pins as Outputs
  pinMode(stepPin,OUTPUT);
  pinMode(dirPin,OUTPUT);
  digitalWrite(dirPin,HIGH); // Enables the motor to move in a particular direction
  // Makes 400 pulses for making one full cycle rotation
  for(int x = 0; x < 10000; x++) {
    digitalWrite(stepPin,HIGH);
    delayMicroseconds(500);
    digitalWrite(stepPin,LOW);
  delay(1000); // One second delay
  digitalWrite(dirPin,LOW); //Changes the rotations direction
  // Makes 400 pulses for making two full cycle rotation
DangerToMyself
In that sketch, you would need options for delayMicroseconds and a method for selecting those options.
So, you'd have something like
if medium is selected
     x = 500
If slow is selected
    x = 750
Then you would delayMicroseconds(x);
Of course selecting the speed is a whole other can of worms. You could opt for a button (or buttons), a potentiometer, base it on temperature, light brightness, etc etc.
