Topic: Arduino serial communication and uploading program to a specific arduino (Read 542 times) previous topic - next topic
Nahian_Alindo
How to fetch the com port or any id I can use to upload specific program to a specific arduino?
My project is a head mouse for which I am using two arduino boards . I want to upload a specific program to a specific arduino. How can I do it? And if I need to use a pid or com port id about which the official arduino forum people suggested, how can I retrieve this id? I'm using an Arduino micro and a pro micro if it helps any.
Robin2
What PC operating system are you using?
On Linux if I am careful to connect my Arduinos in a specific order I can be sure which one is on ttyACM0 and which is on ttyACM1
I have written a short Python program to compile and upload my code using the Ardunio IDE command line. At the top of my .ino files I have some comments like this which tell Python which serial port to use
Code: [Select]
// python-build-start
// action, verify
// board, arduino:avr:uno
// port, /dev/ttyACM0
// ide, 1.8.6
// python-build-end
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
sterretje
The information that you're looking for is the USB VID and PID of the USB device after you've reset the board. They are unique for each device model.
You can find them in Windows device manager (or the linux/mac equivalents). I suspect that you can also find it the the boards.txt file, but I'm not behind a PC at the moment to check.
You will have to explain how you intend to use the information and which OS you're using.
If you understand an example, use it.
If you don't understand an example, don't use it.
Electronics engineer by trade, software engineer by profession. Trying to get back into electronics after 15 years absence.
Robin2
I think that means that two Unos (for example) would report the same values?
...R
Nahian_Alindo
...R
Actually I am using an Arduino Pro Micro to get the cursor movement data and an Arduino Pro to get and send  data from the Electrohouse voice recognition module V3.1. I am using Windows 10 64 bit for the operating system. I want to retrieve the USB VID or PID to use it in my code to upload it to a specifice arduino such as the .hex file of the "a.ino" to the micro and "b.ino" to the pro micro one at a time. This project I am doing is a client project. Thus, I can't make the user to connect the arduino to specific usb ports to connect the boards in a specific order. Because the arduino boards and the other components connected to it will be hidden inside a box or something for abstraction and the user won't know which cable connects to a  specific arduino.
sterretje
...R
To my knowledge, yes.
Robin2
I think that will require a third "computer" inside the device that can receive the new code from the user and route it to the appropriate Arduino. A RaspberryPi should be able to do that nicely - but there are probably other options.
...R
sterretje
It probably can be easier (no need to use VID and PID). Below example using powershell to find the serial ports, filter for a Leonardo and reset the Arduino; tested on Windows 8. I did not add the upload part
Code: [Select]
# regular expression pattern to detect specific device
$reSerial = "(Arduino Leonardo) \((COM\d+)\)"
$reBootloader = "(Arduino Leonardo bootloader) \((COM\d+)\)"
# get serial ports
$devices = (gwmi -query "select * from win32_pnpentity" | where {$_.Name -match "COM\d+"}).name
$port = "N/A"
$arduino = "N/A"
# loop through ports
foreach ($dev in $devices)
  # and find arduino serial port
  if($dev -match $reSerial)
    $arduino = $Matches[1]
    $port = $Matches[2]
Write-Host $port
Write-Host $arduino
# open and close port at 1200 baud to force a reset
$serial= new-Object System.IO.Ports.SerialPort $port,1200,None,8,one
$serial.open()
$serial.close()
# wait a little
Start-Sleep -Seconds 2
# get serial ports
$port = "N/A"
$arduino = "N/A"
  if($dev -match $reBootloader)
    $port = $Matches[2]
Write-Host $port
Write-Host $arduino
# upload here
Output
Code: [Select]
COM28
Arduino Leonardo
COM29
Adjust (and harden) to your needs ;)
PS
Please be aware that your clients might not necessarily use Windows :)
