Topic: was not declared in this scope {again} (Read 1 time) previous topic - next topic
Leetut
im trying to copy the relevant parts of "Meter1copy"
into "touch_graph_white
Robin2
#31
Oct 09, 2019, 03:52 pm Last Edit: Oct 09, 2019, 03:54 pm by Robin2
that is the error message, and the sketch
Sorry, my mistake - I thought it was just the program. (Senior moment :) )
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
TheMemberFormerlyKnownAsAWOL
This  bit
//  Draw the analogue meter on the screen
void analogMeter()
  tft.setTextColor(ILI9341_BLACK);  // Text colour
  tft.fillRect(0, 0, 240, 100, meterCream);
  // draw meter background
  int h = 53, w = 240, row, col, buffidx = 0;
  for (row = 0; row < h; row++) { // For each scanline...
    for (col = 0; col < w; col++) { // For each pixel...
      //To read from Flash Memory, pgm_read_XXX is required.
      //Since image is stored as uint16_t, pgm_read_word is used as it uses 16bit address
      tft.drawPixel(col, row, pgm_read_word(vumeter + buffidx));
      buffidx++;
    } // end pixel
  plotNeedle(0, 0); // Put meter needle at 0
Leetut
This  bit
void analogMeter()
      buffidx++;
    } // end pixel
no, ive already added that part, everything else
Leetut
#34
Oct 09, 2019, 07:30 pm Last Edit: Oct 09, 2019, 07:33 pm by Leetut
I don't want anything drawn on the screen until I press a button
   if ((p.x > 2880) && (p.x < 3840) && (p.y > 313) && (p.y < 3680))
      //  If Meter Button is touched Draw the analogue meter on the screen
          buffidx++;
        } // end pixel
    // Update needle position
    // This function is blocking while needle moves, time depends on ms_delay
    // 10ms minimises needle flicker if text is drawn within needle sweep area
    // Smaller values OK if text not in sweep area, zero for instant movement but
    // does not look realistic... (note: 100 increments for full scale deflection)
    void plotNeedle(int value, byte ms_delay)
      tft.setTextColor(TFT_BLACK, meterCream);
      char buf[8]; dtostrf(value, 4, 0, buf);
      tft.setCursor(5, 80);
      tft.print(buf);
      if (value < -10) value = -10; // Limit value to emulate needle end stops
      if (value > 110) value = 110;
      // Move the needle util new value reached
      while (!(value == old_analog)) {
        if (old_analog < value) old_analog++;
        else old_analog--;
        if (ms_delay == 0) old_analog = value; // Update immediately if delay is 0
        float sdeg = map(old_analog, -10, 110, -150, -30); // Map value to angle
        // Calcualte tip of needle coords
        float sx = cos(sdeg * 0.0174532925);
        float sy = sin(sdeg * 0.0174532925);
        // Calculate x delta of needle start (does not start at pivot point)
        float tx = tan((sdeg + 90) * 0.0174532925);
        // Erase old needle image
        tft.drawLine(120 + 20 * ltx - 1, 119 - 20, osx - 1, osy, meterCream); //119
        tft.drawLine(120 + 20 * ltx, 119 - 20, osx, osy, meterCream);
        tft.drawLine(120 + 20 * ltx + 1, 119 - 20, osx + 1, osy, meterCream);
        // Store new needle end coords for next erase
        ltx = tx;
        osx = sx * 118 + 120; // 188 + 120
        osy = sy * 38 + 85; // 98 + 140 , 38 + 85
        // Draw the needle in the new postion, magenta makes needle a bit bolder
        // draws 3 lines to thicken needle
        tft.drawLine(120 + 20 * ltx - 1, 119 - 20, osx - 1, osy, 0xc801);
        tft.drawLine(120 + 20 * ltx, 119 - 20, osx, osy, 0xc801);
        tft.drawLine(120 + 20 * ltx + 1, 119 - 20, osx + 1, osy, 0xc801);
        // Slow needle down slightly as it approaches new postion
        // if (abs(old_analog - value) < 10) ms_delay += ms_delay / 5;
        // Wait before next update
        //  delay(ms_delay);
Arduino: 1.8.10 (Mac OS X), Board: "Generic STM32F103C series, STM32F103CB (20k RAM. 128k Flash), Serial, 72Mhz (Normal), Smallest (default)"
/Users/lee/Desktop/touch_graph_white/touch_graph_white.ino: In function 'void loop()':
touch_graph_white:211:26: error: 'plotNeedle' was not declared in this scope
     plotNeedle(reading, 0); // Update analogue meter, 0ms delay per needle increment
/Users/lee/Desktop/touch_graph_white/touch_graph_white.ino: At global scope:
touch_graph_white:214:1: error: expected unqualified-id before '{' token
/Users/lee/Desktop/touch_graph_white/touch_graph_white.ino: In function 'void DrawBarChartP1(Adafruit_ILI9341&, double, double, double, double, double, double, double, double, int, int, unsigned int, unsigned int, unsigned int, unsigned int, unsigned int, String, boolean&)':
touch_graph_white:781:22: error: 'plotNeedle' was not declared in this scope
touch_graph_white:792:5: error: a function-definition is not allowed here before '{' token
touch_graph_white:843:1: error: expected '}' at end of input
Multiple libraries were found for "Adafruit_ILI9341.h"
 Used: /Users/lee/Documents/Arduino/libraries/Adafruit_ILI9341
 Not used: /Users/lee/Library/Arduino15/packages/stm32duino/hardware/STM32F1/2019.6.29/libraries/Adafruit_ILI9341
Multiple libraries were found for "SPI.h"
 Used: /Users/lee/Library/Arduino15/packages/stm32duino/hardware/STM32F1/2019.6.29/libraries/SPI
Multiple libraries were found for "XPT2046_Touchscreen.h"
 Used: /Users/lee/Documents/Arduino/libraries/XPT2046_Touchscreen
Multiple libraries were found for "Adafruit_GFX.h"
 Used: /Users/lee/Documents/Arduino/libraries/Adafruit_GFX_Library
exit status 1
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
Error messages without the code to which they refer are utterly useless.
UKHeliBob
This is very explicit.  You have at least one } missing at the end of the code
Have you posted the code that produced the error ?
Leetut
sorry I thought I did, I have now, adding 1 or 2 or 3 } at the end makes no difference
#38
Oct 09, 2019, 07:39 pm Last Edit: Oct 09, 2019, 07:40 pm by TheMemberFormerlyKnownAsAWOL
That should be hard against the left margin.
That it isn't suggests it is embedded in another function.
Leetut
Tried moving it up down left and sideways, errors every time
UKHeliBob
Have you posted the complete program ?
Leetut
full sketch and its errors
exit status 1
UKHeliBob
  if (updateTime <= millis())
    updateTime = millis() + 0;
    int reading = 0;
    reading = map(analogRead(PB0), 0, 4195, 0, 100);
{  //<<<<<<< WHAT IS THIS NONSENSE ALL ABOUT ?  WHICH FUNCTION IS THE CODE IN ?
  p1volts = analogRead(PA0);
  p2volts = analogRead(PA1);
I am about to give up.
See my comment added to the code portion above
Leetut
not sure which nonsense you're referring to, the { you're pointing at or above it
either way both are like that originally
  if (updateTime <= millis()) {
    int reading = 0;
  p3volts = analogRead(PA2);
  p4volts = analogRead(PA4);
  p5volts = analogRead(PA3);
  DrawBarChartP1(tft, 10, 134, 140, 7, 0, 4195 , 409, p1volts, 0, 0, GREEN, DKGREY, BLACK, WHITE, BLACK, "POT1", graph_1);
  DrawBarChartP1(tft, 10, 177, 140, 7, 0, 4195 , 409, p2volts, 0, 0, GREEN, DKGREY, BLACK, WHITE, BLACK, "POT2", graph_2);
  DrawBarChartP1(tft, 10, 220, 140, 7, 0, 4195 , 409, p3volts, 0, 0, GREEN, DKGREY, BLACK, WHITE, BLACK, "POT3", graph_3);
  DrawBarChartP1(tft, 10, 263, 140, 7, 0, 4195 , 409, p4volts, 0, 0, GREEN, DKGREY, BLACK, WHITE, BLACK, "POT4", graph_4);
  DrawBarChartP1(tft, 10, 306, 140, 7, 0, 4195 , 409, p5volts, 0, 0, GREEN, DKGREY, BLACK, WHITE, BLACK, "POT5", graph_5);
Leetut
still not working
touch_graph_white:777:26: error: 'plotNeedle' was not declared in this scope
touch_graph_white:782:18: error: 'plotNeedle' was not declared in this scope
touch_graph_white:793:1: error: a function-definition is not allowed here before '{' token
exit status 1
   // Meter Code -------------------------------------
          buffidx++;
        } // end pixel
    int reading = 0;
  tft.print(buf);
    else old_analog--;
    ltx = tx;
    //  delay(ms_delay);
