Topic: Common Cathode Large 7 Segment Driver (Read 93 times) previous topic - next topic
engineerdk
I am trying to build a Driver circuit for a Large common cathode 7 segment driving circuit.
I am using Proteus simulator to simulate the circuit beforehand, but after lots of adjustments, I am not getting the results.
Can anyone please tell me if I remove the pullups from both UDN1981 AND ULN2803(as per datasheet standard) will the circuit run in actual Hardware.
Please see the attachment.
Grumpy_Mike
Why do you need those inverters? Simply invert the output in software.
The 2803 will only sink current so the pull up resistors are irrelevant.
MarkT
#2
Oct 10, 2019, 12:50 am Last Edit: Oct 10, 2019, 12:51 am by MarkT
UDN1981 doesn't exist.  Perhaps you mean UDN2981 ?   You certainly don't use pull-up resistors on the output of drivers like this as they are providing current or no current.
[BTW please check the text is legible before posting images containing text!!]
You haven't provided details of the LED display - voltage, current, and whether it has built in current limiting (usually not).  I suspect you'll need to add suitable current limiting resistors on the UDN2981 outputs to the segments.
