Topic: I2S microphone invalid readings (Read 428 times) previous topic - next topic
frodidam
Hi everyone
I am working on a project where I want to have my Arduino MKR1010 functioning as a dB SPL measurement device. I am trying different microphones and have stumbled upon the adafruit SPH0645 I2S mic.
I am currently trying it out with a modified example code, and it seems like a good solution. But it only works for a few seconds and then the readings become invalid (either 0 or -1). Does anyone know why or have an idea of why this is happening? Please see the attached code.
Thank you.
Code: [Select]
 This example reads audio data from an Invensense's ICS43432 I2S microphone
 breakout board, and prints out the samples to the Serial console. The
 Serial Plotter built into the Arduino IDE can be used to plot the audio
 data (Tools -> Serial Plotter)
 Circuit:
 * Arduino/Genuino Zero, MKRZero or MKR1000 board
 * ICS43432:
   * GND connected GND
   * 3.3V connected 3.3V (Zero) or VCC (MKR1000, MKRZero)
   * WS connected to pin 0 (Zero) or pin 3 (MKR1000, MKRZero)
   * CLK connected to pin 1 (Zero) or pin 2 (MKR1000, MKRZero)
   * SD connected to pin 9 (Zero) or pin A6 (MKR1000, MKRZero)
 created 17 November 2016
 by Sandeep Mistry
#include <I2S.h>
  // A baud rate of 115200 is used instead of 9600 for a faster data rate
  // on non-native USB ports
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  // start I2S at 16 kHz with 32-bits per sample
  if (!I2S.begin(I2S_PHILIPS_MODE, 44100, 32)) {
    Serial.println("Failed to initialize I2S!");
    while (1); // do nothing
#define SAMPLES 128 // make it a power of two for best DMA performance
  // read a bunch of samples:
  int samples[SAMPLES];
  for (int i=0; i<SAMPLES; i++) {
    int sample = 0;
    while ((sample == 0) || (sample == -1) ) {
      sample = I2S.read();
      if((sample == 0) || (sample == -1) ) {
        Serial.println("Invalid sample");
    // convert to 18 bit signed
    sample >>= 14;
    samples[i] = sample;
  // ok we hvae the samples, get the mean (avg)
  float meanval = 0;
    meanval += samples[i];
  meanval /= SAMPLES;
  //Serial.print("# average: " ); Serial.println(meanval);
  // subtract it from all sapmles to get a 'normalized' output
    samples[i] -= meanval;
    //Serial.println(samples[i]);
  // find the 'peak to peak' max
  float maxsample, minsample;
  minsample = 100000;
  maxsample = -100000;
    minsample = min(minsample, samples[i]);
    maxsample = max(maxsample, samples[i]);
  float peakPeak = maxsample - minsample;
  float rms = peakPeak/sqrt(2);
  float dB = ((20.0 * log10(rms/1052)) + 69.4);
  Serial.print("RMS counts: ");
  Serial.println(rms);
  Serial.print("SPL: ");
  Serial.print(dB);
  Serial.println("dB");
  Serial.println("");
MarkT
Why would 0 or -1 be invalid?  32 bit I2S samples centre around 0
