Topic: "Help with Arduino control of 1996 Audi A4 B5 climate control" (Read 998 times) previous topic - next topic
AudiArduino
Hello everyone,
I am new to the forum and I introduce myself, I am: AudiArduino, merger of Audi and Arduino because my project ideas have a lot to do with a vehicle of the Audi brand. First of all thank you for having this fantastic forum and I hope to learn things, help and help me. Greetings to all.
As for my project, and researched online and Arduino is a real past seeing all the possibilities that it is capable of doing and that it has.
I understand that for this, knowledge is needed and for them I am here too, to learn a little more about the arduino world and to be able to do interesting things among all.
My idea, intention or project desire is as follows:
I would like to be able to remove the climate control module that controls the temperature of the car, I do not know if it is analog or digital, it is from the year 1996, and the intention would be to cancel this old weather and control the climate of the car through a TFT touch screen , where when giving orders of more or less temperature, speed, ac etc., give the orders to the components for them to carry out.
I do not know if it is viable, I do not know if it is possible and I do not know what steps to follow to see the options of this idea that if materialized, would be sensational and novel for this vehicle.
Thank you all and best regards.
Robin2
#1
Oct 13, 2019, 11:17 am Last Edit: Oct 13, 2019, 11:20 am by Robin2
Almost all of the info needed to answer that depends on your vehicle and what it needs in order to cause the aircon to operate.
You are going to have to figure that out and tell us.
...R
PS ... you will probably get more help with a Title that summarises your problem. You can change the title by editing your Original Post. I suggest something like - "Help with Arduino control of 1996 Audi XXX climate control" If you insert the model name you may be lucky and someone might know about it.
Two or three hours spent thinking and reading documentation solves most programming problems.
AudiArduino
Thank you, I have already changed the title, the model is audi a4 b5 of 1996 and I will put photos of the standard weather and see if you can give order with arduino and a touch screen for the weather to work. It is a project that I would like to create. I will look for weather input and output pins to see what function they have and upload photos of the weather, the wiring if I find it, a photo montage of the desired and the desired TFT arduino.
Robin2
I'm not sure what you mean by that.
If you just want someone to write a program for you please ask in the Gigs and Collaborations section of the Forum and be prepared to pay. However it will be difficult for someone who does not have access to the same hardware as you have.
If you want to learn to program yourself the examples that come with the Arduino IDE are a good place to start. There are also many online tutorials.  Also see the Useful Links Thread.
...R
AudiArduino
With images I will try to explain the desired:
Original interior audi a4 b5 1996, :
Original screen audi a4 b5 1996:
Arduino screen:
Simulation of the desired:
I am also looking for reference and weather pins to see connections and receive more ideas and help.
Thank you
notsolowki
Arduino screen:
Thank you
i was looking for your wiring diagrams in AllData but i dont see a audi a4 B5. only a4 i see is D2 would this be the same wiring u think?
EDIT: i don't show any wiring diagrams for the 96 a4 anyways sorry
AudiArduino
YES, the car is: Audi A4 B5 8D2 1995-1998
I am looking for rows too. thank you very much everyone, I see this project possible
notsolowki
You might have to ask a dealership if they can print out the wiring diagrams for your connectors. Your temp probe outside the car might actually go straight to the BCM. I would ask someone at the parts counter at the dealership for the wiring diagrams.
AudiArduino
I have found the schemes of my climate, they are quite complex as it seems, but it is a matter of studying it well.
On the other hand they are PDF files and I don't know how to upload them here to the forum.
AudiArduino
I enclose PLANS OF MY CLIMATE, they seem complicated.
AudiArduino
I offer paypal donations to those who help me with the plans. Thank you
AudiArduino
Hallo allerseits
Ich bin neu im Forum und stelle mich vor: AudiArduino, Zusammenschluss von Audi und Arduino, weil meine Projektideen viel mit einem Fahrzeug der Marke Audi zu tun haben. Zunächst einmal danke ich Ihnen für dieses fantastische Forum und hoffe, dass Sie etwas lernen, mir helfen und mir helfen können. Grüße an alle.
Was mein Projekt angeht und online recherchiert, ist Arduino eine wahre Vergangenheit, um alle Möglichkeiten zu erkennen, die es zu bieten vermag und die es hat.
Ich verstehe, dass dafür Wissen benötigt wird und für sie bin ich auch hier, um ein bisschen mehr über die Arduino-Welt zu lernen und interessante Dinge unter allen zu können.
Meine Idee, Absicht oder mein Projektwunsch lautet wie folgt:
Ich möchte in der Lage sein, das Klimasteuerungsmodul zu entfernen, das die Temperatur des Autos steuert. Ich weiß nicht, ob es analog oder digital ist. Es ist aus dem Jahr 1996 und die Absicht wäre, dieses alte Klima zu löschen und das Klima des Autos über einen TFT-Touchscreen zu steuern Wobei bei Aufträgen von mehr oder weniger Temperatur, Geschwindigkeit, Klimatisierung usw. die Bauteile angewiesen werden, diese auszuführen.
Ich weiß nicht, ob es machbar ist, ich weiß nicht, ob es möglich ist, und ich weiß nicht, welche Schritte zu befolgen sind, um die Optionen dieser Idee zu ermitteln, die, wenn sie realisiert würden, für dieses Fahrzeug sensationell und neuartig wären.
Mit Bildern werde ich versuchen, das Gewünschte zu erklären:
Original Innenraum Audi A4 B5 1996:
Original bildschirm audi a4 b5 1996:
Arduino-Bildschirm:
Simulation des gewünschten:
Vielen Dank und viele Grüße.
PDF DES KLIMASCHEMAS AUDI A4 B5 1996:
Paul_KD7HB
And what is your plan for this person to test the code they will write for you?
Paul
themanfrommoon
Aus welcher Sprache ist das denn übersetzt?
Tommy56
Vor allem, warum schreit der TO so?
Gruß Tommy
"Wer den schnellen Erfolg sucht, sollte nicht programmieren, sondern Holz hacken." (Quelle unbekannt)
