Topic: Error de copilado para arduino nano (Read 289 times) previous topic - next topic
Fer_help
Oct 16, 2019, 11:07 pm Last Edit: Oct 17, 2019, 03:55 pm by surbyte Reason: Agregado de etiqueta para códigos/errores
Por favor ayudaa, me copilaba bien hasta hace poco
Code: [Select]
Arduino:1.8.9 (Windows Store 1.8.21.0) (Windows 10), Tarjeta:"Arduino Nano, ATmega328P (Old Bootloader)"
Opciones de compilación cambiadas, reconstruyendo todo
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\cores\arduino\HardwareSerial.cpp: In member function 'availableForWrite':
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\arduino\avr\cores\arduino\HardwareSerial.cpp:203:1: internal compiler error: Segmentation fault
Please submit a full bug report,
with preprocessed source if appropriate.
See <http://gcc.gnu.org/bugs.html> for instructions.
lto-wrapper.exe: fatal error: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.21.0_x86__mdqgnx93n4wtt\hardware\tools\avr/bin/avr-gcc returned 1 exit status
compilation terminated.
c:/program files/windowsapps/arduinollc.arduinoide_1.8.21.0_x86__mdqgnx93n4wtt/hardware/tools/avr/bin/../lib/gcc/avr/5.4.0/../../../../avr/bin/ld.exe: error: lto-wrapper failed
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compilando para la tarjeta Arduino Nano.
Este informe podría contener más información con
"Mostrar salida detallada durante la compilación"
opción habilitada en Archivo -> Preferencias.
Deva_Rishi
Oh eh yeah i think this is a known issue, but i don't know the answer, pity you didn't post in English.
To 'Correct' you have to be Correct. (and not be condescending..)
sterretje
The issue serms to have been solved in IDE 1.8.10.
Alternative is to downgrade the board manager to version 1.6.21.
If you understand an example, use it.
If you don't understand an example, don't use it.
Electronics engineer by trade, software engineer by profession. Trying to get back into electronics after 15 years absence.
surbyte
sterretje
No, we suggest to upgrade the IDE or downgrade the board manager.
