Topic: Library to control 16*16 WS2812B full RGB color LED matrix (Read 912 times) previous topic - next topic
SergeS
Could anyone recommend any good advanced free library to control 16x16 WS2812B full RGB color LED matrix?
Looking to draw and animate some graphic primitives such as lines, rectangles, ovals, characters (?), gradients and shifts. I believe some wrappers for FastLED are existing?
SergeS
PaulRB
AdaFruit have a library for ws2812b matrices. But it uses their own NeoPixel library, not FastLED library.
Grumpy_Mike
Wow... No recommendations? Not at all?
Because you don't need a library to control them other than the normal WS2812 drivers. So it is hard to recommend one.
What do you want a library to do for you that is not trivial to code yourself?
Idahowalker
An advanced LED strip library when using the ESP32 is the Adafruit_NeoPixel.h. The ESP32 Adafruit_NeoPixel.h the library is written in C and uses some of the ESP32's OS, freeRTOS, library to facilitate operations.
SergeS
Ok, thank you, will look.
SergeS
Everything that could be done with libraries, also could be done without. The question is in code reuse, if somebody already have done such thing and ready to share, why to reinvent bicycle?
I am looking for library to do, as mentioned above, some graphics primitive figures and operations - draw rectangles, ovals, lines, 2d color gradients, shifts, characters. Probably, it may be not so hard to do by myself, but before starting to work on it, i am looking for library, which can make  the task is easier...
SergeS
Someone has already mentioned library from Adafruit, but it seems to be anothe one. Thank you, will look.
Grumpy_Mike
Because if you can't reinvent the bicycle then you will never learn how to invent anything.
SergeS
BS, I CAN reinvent bicycles and i did it so many times to be fed up with this. So now, before start to do it again, i am looking around  to see what to reuse.
Grumpy_Mike
Quite honestly I don't believe you.
SergeS
Ok, it is not bother me :-) We are here not to believe...
Thanks you to those who point me to Adafruit_NeoMatrix library (https://learn.adafruit.com/adafruit-neopixel-uberguide/neomatrix-library), it is very useful.
SergeS
There are also some good samples here: https://alexgyver.ru/gyverlamp/
Russian language, so Google translator may help.
