Topic: Multiple load cells with a single amplificator on Arduino UNO (Read 147 times) previous topic - next topic
Shiki_Ryougi
Hello to everyone!
I need of your help.
I have to connect two 4-wire load cells to Arduino UNO using just one HX711 amplifier. I have to get a single measure.
I've already done the tests with a single load cell and everything works fine.
How do I do with two?
pylon
Google is your friend! Did you try searching for that? I'm sure you'll find at least a dozen tutorials.
Shiki_Ryougi
I searched on Google ... but I don't understand what I have to do.  It's my first ever project and I know almost nothing about electronics.  I need help.  Please.
pylon
To be honest: that's not a good project to start with.
This page shows you the wiring of a single cell to the HX711 and Arduino. The second cell is connected equally but the two wires A- and A+ (white and green) are connected to B- and B+ instead.
MorganS
But the A and B inputs are different inputs with different gains. Not good if the two gauges are identical.
You can just connect the two in parallel (all 4 wires) to get an average of the two.
Or maybe you need several 2-wire units?
"The problem is in the code you didn't post."
