Topic: When software serial RX is active, bytes are dropped on hardware serial RX (Read 2767 times) previous topic - next topic
kolompos
You can see a scope output attached.
The problem is consistent, but i don't know why it happens.
Other factors:
- the problem does not occur when the software serial pin is disconnected (code not changed)
- the problem persists when the sw serial is not polled, but the wire is connected
The module on the sw serial bus is a GPS
It's a GY-GPSV3-NEO M8M
The library is TinyGPSPlus
Tried directly and with level shifter.
Tried different pin.
Some snippets:
in loop:
Code: [Select]
  if(Serial.available())
    delay(100);
    while(Serial.available())
      helper = (char)Serial.read();
      #ifdef DEBUG_MODE
        Serial.print(helper);
      #endif
      command += helper;
      if(helper == EOL_CHAR)
        command.remove(0,command.lastIndexOf('$')); // delete up to '$'
        #ifdef DEBUG_MODE
          Serial.print("COMMAND IS: ");
          Serial.println(command);
        #endif
        stepOne();
        command = "";
also in loop:
Code: [Select]
  sw_serial_timer = millis();
  do
    while (ss.available())
      gps.encode(ss.read());
  } while (sw_serial_timer + SW_SERIAL_POLL_TIME > millis());
Robin2
Some snippets:
Snippets are a waste of time. Please post the shortest complete program that illustrates the problem.
In the meantime have a look at the examples in Serial Input Basics - simple reliable ways to receive data.
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
kolompos
Almost the bare minimum that produces the error:
Code: [Select]
#include <EEPROM.h>
#include <TinyGPS++.h>
#include <SoftwareSerial.h>
#define DEBUG_MODE
#define EOL_CHAR                '\n'
#define HARTBEAT_LED            8
#define SW_RX_PIN               4
#define SW_TX_PIN               3
#define GPS_BAUD                 9600
#define HARTBEAT_PERIOD         5000
#define SW_SERIAL_POLL_TIME     1000
TinyGPSPlus gps;
SoftwareSerial ss(SW_RX_PIN, SW_TX_PIN);
String command;
uint32_t prew_time, sw_serial_timer;
char helper;
  // pinmodes
  pinMode(HARTBEAT_LED, OUTPUT);
  pinMode(SW_RX_PIN, INPUT);
  pinMode(SW_TX_PIN, OUTPUT);
  Serial.begin(38400);
  ss.begin(GPS_BAUD);
  #ifdef DEBUG_MODE
    Serial.println("---!!!DEBUG MODE ACTIVATED!!!---");
  #endif
  //BOOT OK
  #ifdef DEBUG_MODE
    Serial.println("BOOT OK");
  #endif
  prew_time = millis();
      #ifdef DEBUG_MODE
      #endif
      command += helper;
        command = "";
  if(prew_time + HARTBEAT_PERIOD < millis())
    digitalWrite(HARTBEAT_LED,!digitalRead(HARTBEAT_LED));
    #ifdef DEBUG_MODE
      Serial.println("HARTBEAT");
    #endif
    #ifdef ENABLE_SENSOR
      readSensors();
    #endif
  do
Hope it gives more clue.
The minimal circuit to it is the GPS modul with the UNO. Connected to pin 3&4.
Robin2
My wild guess is that this is the problem
Code: [Select]
do
How long does that take to complete?
In general don't use FOR or WHILE unless their loop completes within a few microsecs. Otherwise you are blocking the Arduino just as surely as using delay()
You should always test mills() using subtraction to avoid problems when millis() rolls over. For example
Code: [Select]
if (millis() - sw_serial_timer >= SW_SERIAL_POLL_TIME) {
(how I hate typing underscores :) )
It is not a good idea to use the String (capital S) class on an Arduino as it can cause memory corruption in the small memory on an Arduino. This can happen after the program has been running perfectly for some time. Just use cstrings - char arrays terminated with '\0' (NULL).
...R
kolompos
In the first post I describe 2 cases that rule out that wild guess.
Other factors:
The latter means that the do while is /* */ -d out.
Is it possible that the hw serial is not entirely hw based and also need some interrupt?
Because sw serial surely needs and during sw serial's interrupt others can not happen.
Robin2
Please post that version of your program.
How long is a single message for {a} HardwareSerial and {b} SoftwareSerial?
...R
kolompos
Code: [Select]
#include <EEPROM.h>
#define DEBUG_MODE
#define SW_RX_PIN               4
#define SW_TX_PIN               3
TinyGPSPlus gps;
String command;
char helper;
  // pinmodes
  ss.begin(GPS_BAUD);
  #ifdef DEBUG_MODE
  #endif
  //BOOT OK
  #ifdef DEBUG_MODE
  #endif
      #ifdef DEBUG_MODE
      #endif
      command += helper;
        command = "";
    #ifdef DEBUG_MODE
    #endif
      readSensors();
    #endif
  do
The hw serial messages are less than 10 char, the sw serials are GPS NEMA sentences, about 50 chars or so.
Robin2
Am I correct in my understanding that with the code in Reply #6 you miss some HardwareSerial data when something is connected to Pin4 and you do not miss any data when nothing is connected to Pin4?
What are you connecting to Pin4 for this test?
I have rarely used SoftwareSerial and I have no idea what might be causing the problem. What is the interval between the 10-character messages?
Maybe try AltSoftSerial or NeoSWSerial?
...R
kolompos
Yes, you are. Also, on the first post, in the attached image, I do not miss data when hit the uC in the pause of the GPS modul.
They are the NEMA sentences from the GPS modul. They are sent every second or so.
!Changed the sw serial library to the suggested NeoSWSerial one, and now it is fine!
I have no dropped char on the hw serial. I think it had sometging to do with the interrupts. I haven't checked with scope, but before 80% of the messages were cut, now I can't find one.
So... let's call it SOLVED ? Although the mystery isn't solved.
Robin2
The standard SoftwareSerial library is not great.
...R
