Topic: uploading problem (Read 143 times) previous topic - next topic
MrTerliGomlek
hello, i have a problem, i cant upload my program to arduino uno, i am new with arduino i have just bought it and also i am very new with my operating system which is ubuntu linux. i dont know is the problem is because of arduino or because if my OS. i think the IDE cant see the usb port but im not sure. this is the error message that i have received from arduino IDE.
Arduino: 1.8.10 (Linux), Board: "Arduino/Genuino Uno"
Sketch uses 924 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
thank you
Budvar10
#1
Oct 21, 2019, 07:34 pm Last Edit: Oct 21, 2019, 07:35 pm by Budvar10
First of all, you have to be sure whether the device port is visible by OS. Port should be dimmed under IDE.
Frequent problem of Lnx users is missing rights for the device. You could try it under root, it should work if this is the case. Anyway, you should follow this:
https://www.arduino.cc/en/guide/linux
Arduino clone with ATmega1284P   http://forum.arduino.cc/index.php?topic=277260.0
pert
#2
Oct 22, 2019, 12:26 am Last Edit: Oct 22, 2019, 12:27 am by pert Reason: Fix link
It looks like @MrTerliGomlek has now progressed on to a new error message:
https://forum.arduino.cc/index.php?topic=642134
