Hello spencerkim.
Thank you for sharing your issue with the Arduino community.
I would suggest you try the following:
- Try a different USB cable ensuring it is a data cable.
- Make sure the you plug in the cable directly onto a USB port 2.0 (do not use USN hub)
- Try a different computer and check if you obtain the same result
- Perform a loop-back test following
these instructions to determine if the serial communication of the board works:
If none of the previous steps solve the problem contact Arduino Technical Support to inspect a possible faulty board.
