Topic: ESP12E motorshield analogWrite issue when powering DC motor (Read 310 times) previous topic - next topic
asavale1
I am relatively new to adruino and this whole space. I am currently trying to power a DC motor using an ESP12E motor shield and an ESP8266 Module
Motor Shield - https://www.amazon.com/gp/product/B078CPZDW1/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
ESP8266 - https://www.amazon.com/gp/product/B010O1G1ES/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
DC Motor - https://www.amazon.com/gp/product/B07MTT7B88/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Here is my code
#define DIRA 0
#define PWMA 5
#define LED 2
  Serial.println();
  Serial.println("Starting...");
  Serial.println("Preparing motor...");
  pinMode(DIRA, OUTPUT);
  pinMode(PWMA, OUTPUT);
  analogWrite(PWMA,0);
  digitalWrite(DIRA,1);
  delay(5000);
  Serial.println("Starting motor...");
  analogWrite(PWMA,5);
  delay(5000);
I am expecting the motor to start once I upload this code but nothing is happening. If I change the analogWrite to digitalWrite, the motor runs but I want to be able to control the speed, rather than just having it run at one speed.
I have tested using analogWrite by changing the intensity of an LED and it was working, although the output pin was not the same as the one I use for the motor.
Would greatly appreciate any help as I have already gone through pages of google searches without any luck. I have been using this example as a reference, https://hackaday.io/project/8856-incubator-controller/log/29291-node-mcu-motor-shield.
Thank you in advance
rtek1000
Please avoid private messages, your question may be someone's answer in the future!
asavale1
@rtek1000 Thank you for the link but I'm not sure what to be looking, could you please give me a hint.
I am trying to relate what is shown in the link to my setup but having some difficulty.
Thank you!
JCA34F
A PWM value of 5 may not be enough to start the motor, start with 60 or so, then slow it down.
asavale1
@JCA34F I have tried setting the PWM to 100 and still nothing.
TomGeorge
Thanks... Tom... :)
Everything runs on smoke, let the smoke out, it stops running....
asavale1
asavale1
Turns out I wasn't providing a large enough value for analogWrite. Once I updated it to something more than 250 I was able to get the motors to rotate. Thank you to everyone for their help!
