Topic: Desktop CNC advice request (Read 29895 times) previous topic - next topic
DangerToMyself
Oct 21, 2019, 04:59 pm Last Edit: Oct 31, 2019, 11:34 am by DangerToMyself
This topic was originally placed in the "General Discussion" forum and has since been moved.
I've been wanting to get in to CNC machining for a few years now. I'm a hobbyist woodworker and DIYer and having the ability to make more intricate parts would make some of my ideas easier to accomplish. And, I'd like to possibly produce my own PCBs some day.
Eventually, I would like to have a larger stand alone machine capable of handling a 4' sheet of plywood. And who knows? Maybe even design and build my own. But for now, I think a smaller unit would be better for me at this time due to space limitations, etc.
I'm still in the process of researching machines. So, if you have experience with one or more of these small machines, feel free to tell me about it. Pros, cons, etc. I'm looking for machines capable of working with wood and plastics. Machining aluminum would be a plus. But in no way a "requirement".
I would really like to hear from anyone with advice on the software side to use on a Linux based computer. There are vast amounts of information available on Winblows based programs. But it seems most of what I'm finding about Linux programs is just lists of what's available. Or Joe Schmoe raving "X program is the best", without really telling why he thinks that way.
And if you have any good links to useful resources, feel free to reply.
Thank you for your time!
Robin2
This a Forum for helping people with their own Arduino projects. It is not a Linux forum.
I suspect you will get a lot more help on some of the many CNC forums.
Are you aware that there is a program called LinuxCNC ?
...r
Two or three hours spent thinking and reading documentation solves most programming problems.
ballscrewbob
#2
Oct 21, 2019, 07:19 pm Last Edit: Oct 21, 2019, 07:19 pm by ballscrewbob
If you are going to buy a small machine off the shelf so to speak please make sure there are NO 3d printed parts involved. You may have to pay a little extra for such a machine but you will thank me later LOL.
Once you get above a certain size the G-CODE control mechanisms change from mostly GRBL based to MACH based.
However once you have played with a smaller machine moving up to a MACH based machine is quite a short learning curve as you will already have most of the basics down pat.
Better also to avoid those that have the Arduino NANO based control board approach and go for the UNO based.
Currently use my stuff mostly on hardwood so I know if I slow them down even just a small amount they would also be fine for Aluminium.
Don't know what your budget is but a decent size laser of 5W or greater is a fantastic addition and opens up the machine to a lot of new areas.
Don't use Linux here so cannot say much in that aspect.
Bob
This pic might get your juices flowing LOL
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google (who would have thunk it ! ) or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
DangerToMyself
...r
This is why I asked in this part of the forum. After all, it's description is
Feel free to talk about anything and everything in this board.
The many CNC forums you speak of are typically geared toward professionals ( or at least seem to be ) with high end machines. I've not, to this point, found one that has a section for hobbyists/noobs that really gets any traffic. For instance, the one I found this morning. The last post/reply was back in May of this year.
As for LinuxCNC, I have seen mention if it in my research. However, most, if not all, I've read on it were sales pitches, for lack of a better term.
I will indeed seek more information on that particular program. Thanks!
DangerToMyself
Bob
Thank you very much!
I had read elsewhere to avoid machines with 3D printed parts. But nothing I have read has explained why. I can assume that it has to do with the parts being too flexible or break/wear out.
I had no clue there was a need to use Mach for larger machines.  I figured that the computing would be pretty much the same regardless if size.  But there will time to figure that out later.
And the laser is something I have thought about. And I may go that route to start with in my learning process. Just thinking with a laser there are no expensive cutters/bits to break!
Did you make that clock? Awesome!
DangerToMyself
Just went to the LinuxCNC website. Looks like I have some reading to do. Thanks again for bringing it up. Not sure why I had not went to the source on that one until now.
ballscrewbob
Dang...
I knew you were going to ask a couple of "WHY ?"
OK the 3d parts from China and most others will fail for a few reasons.
Infill not sufficient
Cheapest plastic used for the extruder or even re-used plastic used to make the plastic.
30-60% less compression strength.
There are more but those are the main reasons to avoid 3d parts.
As for GRBl to MACH it is pretty simple and more to do with power requirements and motor drivers.
You would be taking that big leap from hobby to semi pro and looking for longer term durability.
That said I probably have a few thousand hours on my hobby machine and the same on the two laser based home brew machines (printers and plywood and chewing gum approach).
Lasers can bring thier own minor issues in that FLAT OBJECTS are mostly the the things you can do until you get into 4th axis or fancy surface tracking. (can be a steep learning curve)
Yes The clock is only one of many wonderful objects I made that keep the wife gasping and allowing me to spend so much time with Arduino and my machines. It was simply a combination of open source artwork / clipart put together in a couple of hours and then machined into a chunk of red maple.
Bob.
Robin2
Just out of curiosity did you use GRBL or MACH3 to make your clock face?
It seems to cost money and I can't find out how you interface it to hardware - presumably it is just a tad more modern than LinuxCNC and is not expecting you to have cobweb infested PC with a parallel port :)
...R
DangerToMyself
#8
Oct 21, 2019, 08:33 pm Last Edit: Oct 21, 2019, 08:34 pm by DangerToMyself
I still think it's awesome. More evidence to support the "Happy Wife = Happy Life" rule!
PS.
Thanks for the explanations!!
ballscrewbob
#9
Oct 21, 2019, 08:42 pm Last Edit: Oct 21, 2019, 08:50 pm by ballscrewbob
Hi R2.
Was going to ask how you are doing with your set up.
I have not yet made the move to MACH based machines but am pretty close as I need a larger machine.
But currently all done using GRBL based machines.
All the simple UNO with a CNC shield on top.
Gone through about 5 driver boards but almost all of my own stupidity by hogging down the machines.
But they are pennies anyway really.
I have a copy of ARTCAM (now defunct) that makes most of the work easy to do simply based on artwork.
There are a few open source packages but I have taken to this pretty well and it came with the first machine I got off the shelf so not looking a gift horse in the mouth.
Most of the newer MACH is USB based or you can even step it up to standalone too.
We all find different packages more to our liking for ease of learning.
I know you like your linux and I like my windows.
Bob.
Side note for Danger is that with cheap diamond bits from China you can also lightly engrave on stone ! Or with a 10/15W laser also write directly on quite a few types of stone.
DangerToMyself
Hadn't even given working with stone a thought. That's pretty cool though. I'll keep that in mind. Thanks for sharing.
ballscrewbob
@Danger.
WARNING...These things can get very addictive and almost any object within arms reach can become a target for these little machines...."I wonder IF.....Oh I know what would be pretty cool to do...Hey just stick your hand on here for a few minutes....Oh I saw some wooden skids just down the road i will be right back...Hmmm now how can I modify this little $#!% to make it work better.
DangerToMyself
Dang it ballscrewbob!
I'm over 50. Bladder control isn't a problem yet. But ya ain't gotta test it like that! That was friggin funny.
Robin2
As usual I got sidetracked. I have spent several very enjoyable weeks building a Python program that is a GUI front end for the OpenSCAD 3D modelling program. Unless you use OpenSCAD I doubt if it will have any interest but there is a short video here.
...R
ballscrewbob
Oh and did I mention making paint stencils with the laser.
