Topic: IR Remote with Morse code (Read 86 times) previous topic - next topic
jasoncoll10
Hello, so i want to make something that when i click a button on the IR Remote, it will give me a dash or a got and then put those dashes and dots on the serial monitor, and then click another button to say that the word is finished and then it will write the word in english after i finish writing it in morse
MorganS
Which IR remote? Do you already have a particular one in mind?
Do you have the IR receiver already hooked up to your Arduino? Which one?
Which Arduino?
"The problem is in the code you didn't post."
jasoncoll10
I don't know the name specifically, it was a kit I bought with the Arduino mega 2560, it just says Infrared Receiver. I have it all hooked up, all I need is some of the code or to understand how to do the code.
I already have all the HEX values for all the buttons on the remote.
But now I want to get the 0 and use that as dot and the 1 has a dash and input that to the serial monitor and then click the power button to say that I am finished
for example, I will click 001 Power button
the serial monitor would say ..- and then the letter 'A'
I don't know if that makes sense lol
ballscrewbob
That may be the slowest morse code method I have seen.
Also Morse code for A is simply DOT DASH and not 001 (dot dot dash)
There are quite a few morse Arduino sketches around which would modify quite quickly to IR as most already use an LED which you could simply replace with the IR LED.
One such example HERE
Let google be your friend and simply search for "arduino morse code"
Bob.
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
