Topic: Casting question (Read 991 times) previous topic - next topic
__Tango
Hey folks, I'm doing some float calculations and something is working in a way i didn't expect and i'm not sure why.
float wAvg = 5789.5615;
unsigned long tDiffMillis = 1011;
float distance = 0.01169;
    Serial.begin ( 115200 );
    Serial.println ( ( wAvg * tDiffMillis / ( 3600 * 1000 ) ) / distance, 3 );
    Serial.println ( ( wAvg * tDiffMillis / ( 3600000 ) ) / distance, 3 );
The first line prints
-111764.601
which is wrong, but the second line (which seems equivalent to me) prints out the correct value of
139.085
I tried this on a linux based machine converting it to C:
#include <stdio.h>
int main ( int argc, char **argv ) {
    printf ( "%.3f\n", ( wAvg * tDiffMillis / ( 3600 * 1000 ) ) / distance );
    printf ( "%.3f\n", ( wAvg * tDiffMillis / ( 3600000 ) ) / distance );
and the proper value is printed both times.
Can someone help me figure out what i'm missing?
Thanks.
PaulS
3600 is an int. 1000 is an int. The result of the multiplication is an int.
3600UL * 1000UL should result in the same output as the code with the 3600000 (which I wouldn't have expected to work). The compiler treats literals as ints, and 3600000 does not fit in an int.
AWOL
You need to remember that an "int" on an Arduino is 16 bits, so 1000 * 3600 = -4480.
A 32 bit Linux machine will have 32 bit "int"s
johnwasser
33600UL * 1000UL should result in the same output as the code with the 3600000 (which I wouldn't have expected to work). The compiler treats literals as ints, and 3600000 does not fit in an int.
The compiler is smart enough to use a 'long' for integer constants that won't fit in an 'int'.
(Just constants like 3600000, not constant expressions like 3600*1000)
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
__Tango
#4
Jun 17, 2011, 04:10 pm Last Edit: Jun 17, 2011, 04:12 pm by __Tango Reason: 1
Ah...that's it. I didn't realize the compiler would cast like that.   Thanks all! :)
