Topic: Replace SerialMonitor with HyperTerminal/Putty/... (Read 576 times) previous topic - next topic
KennAnderson
Hello, I am a newbie. Is there a way to replace Arduino's "SerialMonitor" with a more powerful app such as HyperTerminal (HT) or Putty? I want to easily capture a serial I/O stream to a file. HT and Putty have a simple logging option whereas "SerialMonitor" does not. I just need to save some 10k bytes from a serial I/O for analysis by Excel. Can anyone help?
spycatcher2k
You don't need to replace anything, just don't open the serial monitor, and run your serial program, opening the correct serial port. I use PUTTY my self, as I prefer this to the built in monitor.
Mrs Drew
UK Based PCB Manufacturing - PM for details
I will design & code for you, but I will also charge you (PM me)
Use Google or search this site BEFORE asking!
sterretje
RealTerm is my choice under Windows. Command line invocation even allows to suppress the usual auto-reset feature of the Arduino.
If you understand an example, use it.
If you don't understand an example, don't use it.
Electronics engineer by trade, software engineer by profession. Trying to get back into electronics after 15 years absence.
