Topic: Cannot decode message (Read 1 time) previous topic - next topic
BigMike81
Oct 30, 2019, 10:21 pm Last Edit: Oct 31, 2019, 04:51 pm by BigMike81
Hello,
I just cannot decode my sensors data...
Here are relevant parts of my code:
Code: [Select]
typedef struct __attribute__ ((packed)) sigfox_message {
  int8_t moduleTemperature;
  int16_t mpcTemperature;
  uint16_t bmePressure;
  uint16_t bmeHumidity;
} SigfoxMessage;
  float pressure = bme.readPressure();
  msg.bmePressure = convertoFloatToUInt16(pressure, 200000);
  float humidity = bme.readHumidity();
  msg.bmeHumidity = convertoFloatToUInt16(humidity, 110);
  tempsensor.wake();
  float outside_temperature = tempsensor.readTempC();
  msg.mpcTemperature = convertoFloatToInt16(outside_temperature, 60, -60);
  SigFox.begin();
  float module_temperature = SigFox.internalTemperature();
  msg.moduleTemperature = convertoFloatToInt16(module_temperature, 60, -60);
  SigFox.status();
  delay(1);
  SigFox.beginPacket();
  SigFox.write((uint8_t*)&msg, 12);
Here is code that handle conversion:
Code: [Select]
#define UINT16_t_MAX  65536
#define INT16_t_MAX   UINT16_t_MAX/2
int16_t convertoFloatToInt16(float value, long max, long min) {
  float conversionFactor = (float) (INT16_t_MAX) / (float)(max - min);
  return (int16_t)(value * conversionFactor);
uint16_t convertoFloatToUInt16(float value, long max, long min = 0) {
  float conversionFactor = (float) (UINT16_t_MAX) / (float)(max - min);
  return (uint16_t)(value * conversionFactor);
Here is custom grammar:
Code: [Select]
Temperature_Int::int:8 Temperature_Ext::int:16 Pressure::uint:16 Humidity::uint:16
Raw and Decoded message is:
Code: [Select]
44221a6f805d7600dc030020
Temperature_Int: 68
Temperature_Ext: 8730
Pressure: 28544
Humidity: 23926
When I print float versions of sensors data to serial monitor, values are correct. What did I wrong?
Thank you.
BigMike81
Got it! I just have to divide my values with conversionFactor. DUH!
