Topic: Powering 5v 1.1a solenoids (Read 179 times) previous topic - next topic
lovehouseparadise
Nov 01, 2019, 01:23 pm Last Edit: Nov 01, 2019, 01:23 pm by lovehouseparadise
I am trying to figure out how much three solenoids will require.
I am using a MOSFET to control the solenoids ( https://www.adafruit.com/product/2776 ) from the arduino but I need a separate power supply for the solenoids.
Was looking at something like this:
https://www.amazon.co.uk/AC100-240V-Transformers-Wireless-Connector-5-5mmx2-1mm-5V-6A-30W/dp/B07P8KR2FJ/ref=sr_1_3?keywords=5v+6a+power+supply&qid=1572610779&sr=8-3
On top of that, could I also provide power to the arduino via USB to mains? Or should I use the barrel DC connector?
wvmarle
3x 1.1A = 3.3A.
You can probably use the same 5V to power the Arduino. Use the 5V pin, that's what it really is for.
Quality of answers is related to the quality of questions. Good questions will get good answers. Useless answers are a sign of a poor question.
gilshultz
DO NOT power from the Arduino, it can only supply a hundred mills or so.  You need another power supply, the one you linked to is adequate.  You can then use a mosfet or relay module to drive the solenoide.  If you use a properly rated avalanche rated MOSFET you will not need the clamp diode.
Good Luck & Have Fun!
Gil
This response is to help you get started in solving your problem, not solve it for you.
Gil
