Hi all,
I am running an arduino uno from my windows 8 PC and have ran into a problem. It very perplexing because this same code worked this time yesterday. I have used this code many times in the past in fact and this is the first time I have had any problems with it. The code is a variation of sweep that makes a servo motor rotate only a set number of degrees from its center of movement. When I press run, the code uploads with no errors, but the 'L' light will flicker then remains on, as does the 'TX' light. I have not changed, or uploaded any of my hardware since yesterday. The arduino is connected to my PC via a USB cord, and powered externally. Any information would be greatly appreciated. The code itself is attached. Thank you.
motor_code.ino (5.09 KB)
