Topic: coil gun question (Read 504 times) previous topic - next topic
tjones9163
Nov 10, 2019, 05:23 pm Last Edit: Nov 10, 2019, 05:24 pm by tjones9163
Hello,     below I will have 2 pictures below,
First) Is an enameled wire that I have wrapped around a plastic tube with 3 layers and each layer has about 120 turns, so 360 turns total. When i hook this up to my power supply through a basic push button ( that I learned not to press with my finger lol) and this draws the max 5amp from my power supply at around 18v.
Second) The other object is a 12v 250ma electromagnet.
I have several questions,
-In my wrapped enameled wire setup I noticed that it only works as an electromagnet when I place a small screw inside the tube and it doesn't work when I try it on the outside. ( I understand that the magnetic flux gets concentrated  inside the tube),
but how is it that the second picture the store-bought 12v electromagnet works better as a contact Electro-magnet and the screw will stick to the side of it.
Is it the method it was wrapped?
-If I am wrapping from left to right in a clockwise manner. When I am finishing the first layer and i am all the way to the right, I keep the wire tight and cross it all the way to the left side in one big turn, then start wrapping from left to right once again. Is that correct? I am pretty sure.
wvmarle
Do look up how magnetic fields look like. The field lines are big circles - concentrated in the core of your magnet, fanning out on the outside.
That store bought battery appears to have a metal case around the coil, I assume iron or a magnetisable stainless steel, that case will also concentrate the magnetic field.
Quality of answers is related to the quality of questions. Good questions will get good answers. Useless answers are a sign of a poor question.
JCA34F
#2
Nov 10, 2019, 06:18 pm Last Edit: Nov 10, 2019, 06:22 pm by JCA34F
Did you measure the resistance of your coil? Did you measure the resistance of the store bought E-magnet?
What was the difference? The E-magnet coil is wound on a core of soft iron (magnet iron) that has high magnetic permeability, what about the core in your coil? Your coil might work as a radio antenna but never as a magnet.   :)
E-magnet
tjones9163
Did you measure the resistance of your coil? Did you measure the resistance of the store-bought E-magnet?
E-magnet
That is a good question, i forgot about the resistance.
I measured the home-made one around 4 OHMS and the store-bought at 50 OHMS, which probably suggests that the store-bought it has more turns of wire.
But, where my home-made coil might not act like a magnet like the store-bought, my version wrapped around a tube is how a lot of basic coil guns are made, so i guess it only has much use when something is inside the air-core coil.
tjones9163
#4
Nov 10, 2019, 11:45 pm Last Edit: Nov 10, 2019, 11:46 pm by tjones9163
Another question, in the picture below, shows that magnetic lines of flux for an air-core coil, just like my home-made setup.
My question is, because of the right-hand rule and the flow of current from positive to negative. Does it matter which side I enter in the screw that I want to project? As of now, the experiment works now on either side I enter the screw when I power it will get attracted to the center. Is one side going to attract the object quicker?
herbschwarz
It will matter only if the screw is magnetized.
Idahowalker
I would start off with 1 coil, narrow in physical width that can be used to suspend an object; like a self stabilizing camera lens.. Once you got that ability, you'd want to duplicate those coils and stack-em on top of each other. Once you get 2 coils you'll want to learn how to manipulate the fields so that you can move the suspended object from 1 coil to the next. Once you are able to move the object from 1 coil to the next, you'll use a stack of coils, with the object suspended between the coils center, move the object up and down the length of your coil stack, slowly. When you have established control of the object suspended in the coils field, you'll then want to 'shoot' you object with a fast signal and blah, blah, blah.
But first, you need to learn how to suspend an object in the narrow width coil.
I won't do your homework, don't ask.
tjones9163
when you say 1 coil, do u mean one wrapped layer or 1 whole coil? In my example I am using a plastic pencil cap which is pretty narrow in width, Also when you say suspend an object, do you mean inside the pencil cap when i apply voltage to the coil to make something like a screw stick to the inside of the coil in the cap. Because that i can do now. Thanks
tjones9163
raschemmel
You can probably use Nick Gammon's
Frequency counter sketch. You can use a
Schottky buffer to covert the signal to
a squarewave.
raschemmel
a squarewave.
Idahowalker
A lens stabilizer.
herbschwarz
The magnetizing force is proportional to
Ampere Turns per Inch. You do not have
to know the Inductance of the coil.
Herb
raschemmel
I said "might" need to know...
